Author Topic: Two Video Cards — Nvidia 3070 ti & AMD  (Read 4339 times)
philexile
  • Last login:October 30, 2022, 03:45:01 pm
  • I want to build my a GroovyMame PC!
« on: September 07, 2022, 10:43:56 pm »
Hello,
I had a quick question: I’m running Windows 10 and wanted to see if it was possible to run both a Nvidia 3070 ti for modern games, and an older AMD VGA card for GroovyMame.
Is this something that can be done?
Thank you
buttersoft
  • Last login:Yesterday at 09:15:01 pm
  • Is running at 15kHz
Re: Two Video Cards — Nvidia 3070 ti & AMD
« Reply #1 on: September 07, 2022, 11:20:50 pm »
How would you like to be a test-case, lol?
In theory it works. In practice there can be a lot of hiccups. I haven't done it myself, i've only seen the complaints.
So, again, how would you like to be a test case?
philexile
« Reply #2 on: September 07, 2022, 11:32:08 pm »
Haha, well, what kind of hiccups? :)
Calamity
  • Moderator
  • Last login:Today at 04:05:22 am
  • Quote me with care
« Reply #3 on: September 08, 2022, 03:52:41 am »
2 gpus -> 2 monitors, super easy
2 gpus -> 1 monitor (i.e. Nvidia for rendering, AMD for output), can be done, but it's complicated. I think RA can do it. I wouldn't want that setup for me or for any loved one though.
Steps to create a log:
philexile
« Reply #4 on: September 08, 2022, 09:36:28 am »
Great! This is exactly what I want to do. I have a very powerful i9 build and I want to use it for both Groovy and modern games. (Though mostly Groovy!) :)
I've never heard of this... what use would this be?
Thanks again!
Sereosh
  • Last login:August 26, 2023, 11:27:13 am
« Reply #5 on: September 08, 2022, 12:18:59 pm »
It works, I did that for a while with my PC with a GTX 970 with two monitors plugged in and a 6450 that had my CRT TV connected to it. Some fiddling around will have to be made in mame so it shows up on the correct monitor, but I never had issues playing games.
I didn't keep that setup because I prefer the convenience of a dedicated arcade PC, but it works if no other alternatives are available.
philexile
« Reply #6 on: September 08, 2022, 01:27:15 pm »
This is good to hear. I will primarily use this for arcades, but i have a 48” OLED that’s I’d like to utilize for modern games as well.
My next question is: what is a good, basic AMD card? I have a more advanced card now and I’ll like to downgrade to save on wattage. I recall that some people recommended to avoid cards with a ribbon connected to the VGA port, but I wasn’t sure if that was hearsay or not.
buttersoft
« Reply #7 on: September 08, 2022, 07:57:19 pm »
IDK specifically what errors ppl are getting. I've heard ppl talk about problems installing, and windows not knowing which driver to use. I'd imagine things are getting better, so go with what Calamity says on that :)
philexile
« Reply #8 on: September 10, 2022, 11:54:16 pm »
Yes — I’m following Calamity’s guidance, always. :)
So, quick question: my AMD Groovy video card is an R9 380 and it a fairly sizable card. Between it and the new Nvidia card, there isn’t much room in my case or between the cards.
Does this high-powered AMD card help with Groovy or could I downgrade to a more modest smaller AMD card, like an HD 5450?
Groovy is my main priority here, and if I need to instead downgrade my Nvidia card for something smaller, so be it!
buttersoft
« Reply #9 on: September 11, 2022, 07:09:45 pm »
It helps, you can use higher frame-delay. A better CPU is more important, but the GPU does matter.
philexile
« Reply #10 on: September 12, 2022, 12:23:15 am »
Are these technical details typed up anywhere?
Also, is there any concern about the dot clock and newer cards?
Thanks again
buttersoft
« Reply #11 on: September 12, 2022, 08:48:00 pm »
Not typed up in one place, Calamity has mentioned it though.
yes, for RX 500 series cards. No dot clock problems reported with R7/R9 300 series AFAIK.
philexile
« Reply #12 on: September 12, 2022, 09:01:23 pm »
Hi again,
We need some of this stuff typed up! There is a very pervasive perception out there that any junker PC will run MAME (or Groovy) and that clearly isn’t the case if you want to get close to arcade-perfect emulation. :)
When I bought the R9 a few years back it was the best, or one of the best, Groovy cards. Is this still the case or has something else eclipsed it at this point?
Thanks again!
buttersoft
« Reply #13 on: September 13, 2022, 08:56:08 pm »
i like a card with an analog output and no dot clock lower limit, myself. I suppose an RX 580 is going to be more powerful - I think that's as high as crt_eumdriver supports now. But you need to make sure you get a compatible hdmi- or DP-to-VGA dongle that can handle 15kHz and also composite sync, if you need that. A lot of cheap newer dongles don't work. I bought like a dozen different ones from Ali and eBay and only one worked. The Tendak adapters won't. The fricking HDMI Fury 2 won't either. That said, a lot of generic older AG6200-based dongles will. Some new ones still use the same old setup, so will work also - you generally have to go brand name like uGreen or Belkin or Comsol or something, but testing one is the only way to be sure.
fuchi_jeg
  • Last login:December 16, 2025, 02:17:57 pm
« Reply #14 on: September 21, 2022, 12:10:46 pm »
Some modern games, especially online games, will complain that test signing must be turned off to play online. It interferes with some anti-cheating software.  A better option is to use dual boot. One instance of windows for CRT, and one for steam/modern games.  In the CRT boot disable the nvidia gpu,  and in the gaming boot disable the CRT gpu. Works for me in windows 10/11.
Rion
  • Last login:Yesterday at 03:42:20 am
  • 240p, 480i
« Reply #15 on: November 24, 2022, 12:23:13 am »
The question is, does it support Interlaced resolutions via DP2VGA
