Author Topic: Aimtrak or similar - consolidating needed cables for power and functionality  (Read 6402 times)
vertexguy
  • ...but this one goes to 11.
Hey all, I'm curious if anyone has come up with an elegant solution for consolidating the needed wires to have an aimtrak that uses either only 1 cable to run the gun and power force feedback, or is the only option a flexible tube covering or something to keep it down to 1 cable visible running to the gun?
I'm also wondering if anyone has come up with a simple automatic reel of some sort to keep the cables tidy when not in use?
I'm getting closer to needing to figure all this stuff out on my build, and am also following mods like gun4Air and rapid fire mods in hopes of one day adopting an even better light gun experience then what is currently possible with Aimtraks.  Once I have that all down and working, I intend on developing some of my own light gun games to help expand the fun for everyone.  Any advice is much appreciated!
« Last Edit: November 18, 2021, 01:45:46 pm by vertexguy »
Titchgamer
You have a few options for the one cable approach.
Aimtrak is obv one as the cable contains the USB for the gun and the Recoil power.
You can get a sinden where the recoil is powered via the USB so the cable is thinner and more manageable than the aim trak but obv dont have the potential power.
Gun4IR well however you make it :)
You could use a modied aim trak cable.
vertexguy
Wait, so I'm confused on this.  I have aimtraks.  So you're saying I can somehow mod the USB cable to power the recoil as well?  I went out and bought 2 power bricks per the ultimarc page instructions to power them, which is then 2 annoyingly separate long cables.
Titchgamer
No you still need the power bricks, but its one cable going up to the gun.
When I had my aimtraks hooked up I hid the power bricks inside the cab so you only saw the 1 cable.
vertexguy
So I no longer need the usb cable for the aimtrak if I have a power brick?  I guess I assumed it was transmitting data on the cable too.
Titchgamer
It does, The USB and the power are built into the same cable but you still have to plug them into their respective sockets.
vertexguy
ok, so to bring the post up to speed with my private messaging, I just learned that because I bought aimtraks without recoil, I don't have the usb cable with the obvious power plug on the end.  The recoil kits I bought also do not have cables included.  After digging deeper on the Ultimarc site, it now looks like I have to buy new cables if I want them all contained in one.  I also have to first disassemble my guns to know if I have the correct module connection inside of them for the cable to work.  So for the time being, I guess I will be looking at some type of hose covering to make the 2 cables into 1. :(
woordmand
  • Last login:January 27, 2022, 01:34:09 pm
0.3m㎡×6
