Author Topic: Lost Galaga Key :(  (Read 2822 times)
JenTime
  • Last login:February 23, 2022, 11:51:57 pm
Lost Galaga Key :(
« on: August 22, 2021, 12:16:36 am »
I have a 1981 Galaga Upright cabinet and I 'know' the key is somewhere in the apartment but I had to move and cannot for the life of me find it.
I believe the cabinet still has original locks as the key I had looked like those double sided Fort 7/8 keys I have seen online (attached image is an example pic), and the one key opened the front coin box and the back access panel.
Does anyone know where I could buy a replacement key, or a good short term fix to get in until I find the key?
I am trying to not have the locks drilled or something else destructive as the cabinet is in very good condition and I don't want to remove original components.
« Last Edit: August 22, 2021, 02:13:07 am by JenTime »
  • Last login:Yesterday at 09:41:48 am
Re: Lost Galaga Key :(
« Reply #1 on: August 22, 2021, 01:52:59 am »
Get a rake lock pick or grind one out.  I made one from the strip of metal in an old wiper blade.  You’ll open that lock in 10 seconds.  Remove the old locks and replace with new ones.
  • Last login:Yesterday at 09:42:52 am
« Reply #2 on: August 22, 2021, 07:30:07 am »
I bought a cheap lock pick set on Amazon. I gave it to my son. He was opening up my cabs within ten minutes of learning to use the picks.
JenTime
« Reply #3 on: August 22, 2021, 02:54:01 pm »
Ahhh... I thought it would be a hard lock to pick as it is keyed on 2 sides.
JenTime
« Reply #4 on: August 22, 2021, 06:36:45 pm »
Eureka!!!!! Found it.
Had been looking for weeks.
Going to place this on a massive keychain so it doesn't get lost again.
Now I can look into the power supply issues.
« Reply #5 on: August 23, 2021, 07:57:18 am »
Convert to a switching power supply?
JenTime
« Reply #6 on: August 23, 2021, 02:13:50 pm »
The key was in the little spare change jar that I had checked twice already. No idea how it folded itself out of our dimension the previous 2 times I checked... but it was there this time.
Also likely going to keep the existing power supply, just repair it if needed. I only turn it on when I play so it isn't like it is being left on for weeks. Plus I prefer to keep it as original as possible.
