Author Topic: Music visualiser on second screen  (Read 2297 times)
DStealth
  • Last login:August 28, 2021, 06:48:52 am
« on: August 17, 2021, 08:48:46 am »
Hi all. Finished Bartop/ Full size arcade (If you see it, you'll know its both  :)) It has a jukebox just for videogame ost's, as I want to keep the gaming theme. One thing I haven't found as yet is a music visualizer that can run on  a second monitor marquee while the main screen is showing the jukebox.  Has anyone found such a thing? I'm currently using BigBox as my arcade front end it that helps.
RandyT
    • GroovyGameGear.com
Re: Music visualiser on second screen
« Reply #1 on: August 17, 2021, 10:52:05 am »
You would need a "stand-alone" visualizer.  Something like G-Force would probably do the trick.  The only thing which might be tricky is getting it to automatically come up on the second display and go to full-screen.  An AHK script might be enough to tackle that issue, but there may be other options out there.  DisplayFusion appears to be one, but it's not free.
DStealth
« Reply #2 on: August 17, 2021, 07:23:59 pm »
Thanks, I'll try it out
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
« Reply #3 on: August 20, 2021, 03:59:11 am »
As I understand it, KODI will run on another display with the visualizer plugins.
