Author Topic: Problem with BLUE ELF 2  (Read 1187 times)
Velho Barras
  • Last login:February 03, 2021, 05:45:47 am
  • Curtes curtir?
« on: February 02, 2021, 02:56:45 pm »
I've bought a Blue Elf 2 (2009) v 2.0 some years ago and it never worked properly, always had image noise. So I set it aside and been using a 60 in 1 vertical game board that works perfectly. But now with this pandemic, I finnaly have time to sort this thing out. The thing is I don't have a clue on what I should do. Please look at the picture in attachment. Can anybody help me please?
Thanks!!!
Greetings from Portugal!!!
Own a monster cabinet arcade where the screen can be used both on vertical and horizontal position!
GUTS!!
the end melody
  • Last login:February 02, 2021, 09:19:19 pm
Re: Problem with BLUE ELF 2
« Reply #1 on: February 02, 2021, 08:57:47 pm »
Hi Velho Barras, welcome to the forums.
You've come to the right place for help.
My guess is, assuming that the Blue Elf unit is working properly, a malfunctioning power supply and voltage problem.
My second guess would be a harness problem of some sort.
I'm sure there are much more knowledgeable members that can help point you the right direction.
« Last Edit: February 02, 2021, 09:02:53 pm by the end melody »
Velho Barras
  • Curtes curtir?
« Reply #2 on: February 03, 2021, 05:32:53 am »
Thanks mate!!!
The unit is functioning, it's playable, but besides that image noise I reported, I don't have the joystick "up" control. Probably a pin out problem on the harness.
Hope someone here can shed a light on this problem.
Big thanks to all the community for all the availiable info, hope to get some answers here.
« Last Edit: February 03, 2021, 05:35:17 am by Velho Barras »
GUTS!!
