Author Topic: Rowe RI-1 Noise When Engaged  (Read 2192 times)
waryan
  • Last login:June 17, 2020, 12:00:39 pm
« on: June 10, 2020, 03:37:20 pm »
I have an RI-1 that I have functioning pretty well, except for one issue. There is a lot of noise when the player starts to engage. I can lift the tonearm up and the noise continues. It is a popping and loud hum. The noise will go up and down with the volume control. My gut tells me this is a grounding issue based on my experience with other hifi systems.
I have a can of deoxit if that can help.
I do believe that monkeying with the pin connection that goes to the RCA plugs makes a difference. Any help is much appreciated. Thank you.
waryan
Re: Rowe RI-1 Noise When Engaged
« Reply #1 on: June 15, 2020, 02:51:50 pm »
I ended up spraying deoxit D5 on just about every connection I could find. Problem solved.
