Author Topic: Crtemu Driver win 7, Hide Modes that the monitor cannot display  (Read 1696 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
I've got a win7 box, radeon r7-260 loaded up with CRTemu driver 2.0 beta 15, and all the modes seem to run correctly, but I can't get Hide Modes that the monitor cannot display to stay set.
For Monitor presets I have a WG25k7131 set, and edid emulation enabled on VGA (It's a DVI-I port, but when I enable on the vga, it does swap to the correct 15k mode)
When I go to display settings, advanced, monitor, the Monitor shows as a Generic PNP Monitor, and I can check the Hide modes button,
Then I can start emulationstation in 15k, but after a restart the setting is unchecked so emulationstation starts in 31k.
Any suggestions?
The setup is running all my emulators correctly.
Thanks.
Later,
dabone
alex2005
  • Last login:December 20, 2023, 09:21:14 am
Re: Crtemu Driver win 7, Hide Modes that the monitor cannot display
« Reply #1 on: May 06, 2020, 01:16:00 pm »
Have you disabled completely the AMD External Events Utility service?
dabone
  • Time to work...
« Reply #2 on: May 06, 2020, 01:29:08 pm »
Thanks! That was it, I knew I had to be missing something easy.
Working fine now.
I used to have a link to a great walkthru for installing crtemu driver under windows, but I can't seem to locate it at the moment.
Next question, where is the right place to ask questions on atom 15?
Thanks again.
Later,
dabone
