Author Topic: How Do I use a regular TV with no S-Video?  (Read 1488 times)
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« on: February 18, 2004, 09:50:58 am »
I have a 20" color TV sitting in my basement collecting durt but it does not have an S-Video input, just a regular cable adapater and some rca jacks. Is there some device that will cobv coax in and a rca in. Is there something that will convert a nine pin seriazl output from my computer into either an rca or coax input for the TV or am I dreaming in technicolor?
If possible and if you've done it, how does the arcade game look? look? Goofy?
Thanks for the help.
Garry
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
Stingray
Re:How Do I use a regular TV with no S-Video?
« Reply #1 on: February 18, 2004, 09:53:53 am »
I've got a RCA/ svid adapter cable. I used to plug my laptop into the composite jack on a TV once to see how it would look. Looked fine to me.
-S
Lilwolf
« Reply #2 on: February 18, 2004, 09:57:30 am »
I haven't heard of anyone getting good results with anything other then scart or svid
You would probably get good results if you had a good converter box (not card)... but I'm talking ones that are a few hundred to a few thousand used for non-home use.
But if you have a tv-out card... the try it and see what you come up with...
