Author Topic: Controller/keyboard problem  (Read 11744 times)
Salamander
  • Last login:April 16, 2020, 03:28:06 pm
« on: April 07, 2020, 01:50:55 pm »
Hi There,
I've finally got the time to finish a cab project I started 6 years ago. I'm using an old Pentium 4 pc running windows XP.
The problem I'm having is that controllers and keyboard stop working in MA about 10 seconds after the menu screen loads. If I enter the MA set up menu they both work. Once I return to menu screen they both stop working.
Would any of you know if this likely to be a software issue(simple fix🤞) or is likely my Jurassic pc causing the problem. Any suggestions would be appreciated before I bite the bullet buy another pc and start the set up again.
