Author Topic: Newbie HAPP 3" Trackball setup  (Read 1297 times)
Wzrd0803
  • Last login:March 25, 2025, 06:27:34 pm
« on: March 25, 2020, 07:42:37 pm »
I was given a Happ trackball by bobbyb13 (Thank you so much!).  It has a six pin Molex connector and green boards.
If I get an Optiwiz 3 and the GGG no solder cable, is that all I need for my arcade cabinet with MAME to use the trackball?
« Last Edit: March 25, 2020, 07:48:43 pm by Wzrd0803 »
  • Last login:Today at 12:18:06 am
Re: Newbie HAPP 3" Trackball setup
« Reply #1 on: March 25, 2020, 10:45:38 pm »
Yes, but you might want to upgrade to red boards, too.
According to the Happ Trackball FAQ, pinouts are the same for the old green boards (A052-1010-00) as the new red boards. (A052-1011-00)
    What are the pinouts of the Optic Sensor pcb A052-1010-00 and A052-1011-00 used on the trackball or trackwheel or 360 steering wheel ?
    These alll use the same Item # A052-1011-00 Optic Sensor Board. The connections are as follows.
    Pin 1 - Output A
    Pin 2 - +5V
    Pin 3 - GND
    Pin 4 - Output B
