January 27, 2026, 07:15:47 am
I was given a Happ trackball by bobbyb13 (Thank you so much!). It has a six pin Molex connector and green boards.If I get an Optiwiz 3 and the GGG no solder cable, is that all I need for my arcade cabinet with MAME to use the trackball?
What are the pinouts of the Optic Sensor pcb A052-1010-00 and A052-1011-00 used on the trackball or trackwheel or 360 steering wheel ? These alll use the same Item # A052-1011-00 Optic Sensor Board. The connections are as follows. Pin 1 - Output A Pin 2 - +5V Pin 3 - GND Pin 4 - Output B
