Author Topic: New Arcade Mame - Beginner woodworker!  (Read 3815 times)
DonBaker
  • Last login:January 16, 2020, 12:47:34 pm
« on: December 04, 2019, 12:51:47 pm »
Hi,
here my first Arcade Build,
*** first time working with a router, and many of the technique need to build a project like this
my side panel (gave me a good chalenge to get those cut straight)
my base (easy part ;)
Assembling without the control panel and monitor bezel :
Now my big challenge.. the control panel to fit my cheap trackball from amazon (2.5inch/4.5cm)
first try :
i was not happy with the result.. so i made another one.
i routed it to be sure the ball was going through.. still not happy with it.. right now i have no idea what i will do with it
I'm open to suggestion .  next step will be the paint for it
**corrected my link
« Last Edit: December 04, 2019, 01:46:30 pm by DonBaker »
  • Last login:Today at 11:47:06 am
Re: New Arcade Mame - Beginner woodworker!
« Reply #1 on: December 04, 2019, 01:20:03 pm »
Some pics of the track ball and of the mounting difficulties would help a lot.
DonBaker
« Reply #2 on: December 04, 2019, 01:47:05 pm »
yeah.. i corrected my link
« Reply #3 on: December 04, 2019, 02:13:42 pm »
It looks like you need to route out the underside of the panel a bit. Can we get a pic of the whole trackball and the underside of the control panel?
  • Online Online
  • Last login:Today at 05:14:05 pm
« Reply #4 on: December 04, 2019, 02:29:33 pm »
For that small square-case trackball, you might want to try the approach that Degenatrons used here.
DonBaker
« Reply #5 on: December 04, 2019, 02:32:04 pm »
i will do tonight.. i dont think i can route more than i did. not much wood left.
« Reply #6 on: December 04, 2019, 02:34:09 pm »
We might have to get creative. The pics will dictate what happens next.
DonBaker
« Reply #7 on: December 04, 2019, 02:36:10 pm »
that really a good idea. i think he screw it from the top.. if i want to that , i think i need to redo my control panel , not much wood left because of the routing trying to make it fit
  • Online Online
« Reply #8 on: December 04, 2019, 03:24:43 pm »
He used threaded inserts -- no hardware visible from the top.
If you don't have enough wood left in the pocket for the inserts, you can use several support bars/straps like the "Under mount (support blocks)" joystick mounting method in the FAQ.
-Put the threaded inserts in an un-routed section of the panel.
« Reply #9 on: December 04, 2019, 05:31:50 pm »
In that example it looks like the ball isn't high enough. Is that just a bad pic?
  • Online Online
« Reply #10 on: December 04, 2019, 07:59:07 pm »
That pic is at a not-so-great angle for depth perception.
- Degenatron's panel is 12mm (1/2"), same thickness as the removed upper cover.
- Moving the threaded inserts to the side like the "Under mount (support blocks)" method increases how high you can mount the trackball.
Two related approaches using a router if you want your trackball to ride higher.
1.  Case top not removed -- case top provides support for the thin part of the control panel
- Route a pocket for the case.
- Route clearance for the catches on the side of the case.
- Use threaded inserts and bars/straps like the "Under mount (support blocks)" method mentioned above.
2. Case top removed
- Route a pocket for the lower case.
- Route an extra 2mm deep clearance slot for each of the two encoder wheels.
  • Online Online
« Reply #11 on: December 04, 2019, 08:46:26 pm »
Several related pics and threads with this type of trackball.
DaOld Man's A Little Rage - http://forum.arcadecontrols.com/index.php/topic,116422.msg1343444.html#msg1343444
processedmeat's IKEAKADE - http://forum.arcadecontrols.com/index.php/topic,135143.msg1394849.html#msg1394849
DonBaker
« Reply #12 on: December 05, 2019, 07:42:23 am »
Thanks for the idea.. i'm going to with with the threaded insert and a plate to support the trackball. i will post some picture this weekend.
DonBaker
« Reply #13 on: December 05, 2019, 07:43:55 am »
here what wood left in the panel. so that will be my best option
DonBaker
« Reply #14 on: December 05, 2019, 09:00:51 am »
Would you add more button to control HyperSpin/Mame. . or i should be ok with those?
  • Online Online
« Reply #15 on: December 05, 2019, 12:04:30 pm »
That is a question of personal preference.
The FAQ lists PROs and CONs regarding dedicated admin buttons and "shifted functions".
http://wiki.arcadecontrols.com/index.php/FAQ#Number_of_admin_buttons
DonBaker
« Reply #16 on: December 05, 2019, 02:38:08 pm »
i should have added a EXIT, PAUSE button.. i will see how i can fit it to the build
DonBaker
« Reply #17 on: December 16, 2019, 08:23:44 am »
it's ALIVE!!
i made a few mistake, it's not perfect.. but it's working and my son and i having a blast.  next one will be better ( dont tell the wife that a second one is comming ;) )
need to fix the marquee , speaker grill , but that's it for now
« Reply #18 on: December 16, 2019, 11:28:52 am »
Nice work.
