Author Topic: rowe 100 amp problem after replacing high output transister  (Read 4799 times)
gmtransman2
  • Last login:August 27, 2022, 10:10:37 pm
« on: November 08, 2019, 11:01:29 pm »
so after all the reading on the amp i took the dive into fixing my amp. remove amp and found the 2 fuses blown on one drive board so replaced the transistors and the fuses. plugged back in and let the smoke out of a couple resisters on the driver board. fuses did no blow. any help would be great thanks
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe 100 amp problem after replacing high output transister
« Reply #1 on: November 27, 2019, 06:39:27 am »
Hello gmtransman2,
More than likely the two larger resistors were already overheated when the fuses and transistor failed.
Check these large fuses and other components on the board. If needs be obtain another driver board and recheck those transistors again, did you put the mica disks on the transistors when replacing them?
Regards
Alan Hood
ami-man
UK
gmtransman2
« Reply #2 on: December 02, 2019, 10:40:11 pm »
yes i did put the mica under the transistor , is there a  good place to buy the transistors in pairs other than ebay. thanks
Ken Layton
  • Guru
  • Technician
« Reply #3 on: December 03, 2019, 12:00:29 pm »
Bruce Wentworth at A & B Jukebox Repair sells the transistors. He specializes in Rowe jukeboxes.
https://www.abjukeboxrepair.com/
  • Last login:Today at 01:03:34 pm
« Reply #4 on: December 16, 2019, 05:21:08 pm »
those pre-driver boards are pretty cheap (i've sen them for about 30 bucks a piece.) they have been redesigned several times to improve performance and reliability over the last 30 some odd years.... if you can find some new ones, it is worth it to replace them.
gmtransman2
« Reply #5 on: February 08, 2020, 01:35:26 pm »
the problem i was having is i bought cheap parts, i ordered 10 pair of transisters and out of the ten pair only two were good. so my problem was trusting new parts and fried my driver boards. put tested good ones in and both drivers boards and i have sound. rebuild two more all good. thank you all for the help.
« Reply #6 on: February 08, 2020, 05:15:30 pm »
10 pairs (properly matched pairs at that) would have cost you close to 200 bucks. that should be your first clue something is up. there are all kinds of fakes out there.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: February 09, 2020, 12:36:12 am »
Especially from ebay.
