Author Topic: game elf 412 in 1 upright two trackballs  (Read 3184 times)
chitlah
  • Last login:November 06, 2020, 04:26:36 pm
« on: October 23, 2019, 06:22:08 pm »
I have the 60 in 1 game elf and both trackballs work but when i got my 412 in 1 i cannot get the
second trackball to work.  The only time it somewhat works is when i use this splitter cable and then
the joystick on player one works up and down and the trackball on player two works left and right
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Re: game elf 412 in 1 upright two trackballs
« Reply #1 on: October 24, 2019, 01:11:25 pm »
Without seeing the whole harness and connection to the trackballs it's difficult to say. But I would suspect you have something wired wrong in the "splitter".  Is that a homemade cable? The cable you buy should have all the wiring for two trackballs.  Or it could be a compatibility issue with the game you're trying to play.
Drnick
  • Plodding Through Life
« Reply #2 on: October 24, 2019, 01:24:42 pm »
See the attachments for pin-outs on the 412 in 1.  and the pin-outs for a 60 in 1  (PLEASE DO NOT TAKE PINOUTS FOR GRANTED, ALWAYS DOUBLE CHECK VOLTAGE and GND)
So looking at that previously you would have had 2 x 6 pin connectors both with gnd and 5v connections, 1 for each trackball,  looks like the new board has 2 x 5 pin and shares 5v and ground.  I'm sure with the pin outs you should be able to create a converter for them.
Hope that helps a bit.
