Hello everyone
i have this problem when i start the JB_GUN4IR_GUI.exe
I have already flashed the arduino, but when I try to configure it, this window appears with this error and the gun is not detected. I built the camera with a wiimote
![](https://blogger.googleusercontent.com/img/a/AVvXsEjVe_pyTrPDBBWJyjewbyRxuoJBYGBU5RxgNzqazKFvCFH4sjhJkHVus-z2jvX0fnSHOXxx6-bqjljG9XnOcQrNSWcUXHB70OloChmzpO9bNrslzZLExnQPgOcuKLeEwQDH3gF71NCOaeBjfHdcFWL2kMeX1d0gPiYa3IIg87a0rNrBEmf2hFpSDKzTcA=s912)
this is the error message
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: The port is closed.
at System.IO.Ports.SerialPort.Write(String text)
at System.IO.Ports.SerialPort.WriteLine(String text)
at JB_GUN4IR_GUI.MainGUI.getEepData(SerialPort _serialPort, Int32 addr, Int32& eepData)
at JB_GUN4IR_GUI.MainGUI.detectArd(Boolean clear, Boolean nbr, String[,] boardList, String name, String board, Boolean isSerial)
at JB_GUN4IR_GUI.MainGUI.detectGuns()
at JB_GUN4IR_GUI.MainGUI.detectBut_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4470.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
JB_GUN4IR_GUI
Assembly Version: 1.22.0.0
Win32 Version: 1.22.0.0
CodeBase: file:///C:/Users/Shin/Documents/proyectos/JB%20GUN4%20IRmanual%20de%20usuario%20v%201.2%20Ingles%20y%20Espa%C3%B1ol/JB_GUN4IR_GUI_1.26_FW_2.64/JB_GUN4IR_GUI.exe
Win32 Version: 4.8.4488.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thank you very much to those who want to help me with this error
