Poll
-- deleted poll --
-- deleted poll --
0 (0%)
-- deleted poll --
0 (0%)
Total Members Voted: 0
Author Topic: GUN4IR - The Ultimate 4 Points Lightgun System  (Read 718851 times)
0 Members and 13 Guests are viewing this topic.
TapeWormInYourGut
  • Last login:Yesterday at 08:20:32 pm
Re: GUN4IR - The Ultimate 4 Points Lightgun System
« Reply #1120 on: March 07, 2024, 07:50:28 am »
Ah I see. I hadn't even thought about how it would act outside of play like that :banghead:
Daniel B.
  • Last login:May 10, 2024, 05:08:12 pm
  • Lightgun and Point Blank enthusiast
« Reply #1121 on: March 18, 2024, 05:15:33 pm »
Ok so it's been a couple of years since I donated. Is this still the most up to date version from my link?
JB_GUN4IR_GUI_1.26_FW_2.64.zip
If not, may I please email you JB for an update?
Additionally, If I purchase this https://rpegelectronics.com/products/universal-gun4ir-diy-pcb?pr_prod_strat=jac&pr_rec_id=6a4074826&pr_rec_pid=7500555387069&pr_ref_pid=7150185021629&pr_seq=uniform
Aside from a gun shell, what else is needed to be purchased? I'm trying to decide if I want to build this or just put sindens on the credit card and hide from my wife.
Thanks all.
Daniel
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
JayBee
  • Last login:July 17, 2025, 11:29:25 am
  • Creator of the GUN4IR
« Reply #1122 on: March 20, 2024, 06:39:42 am »
Thanks all.
Daniel
yes that's the last version so far.
I recently made a full video for the diy pcbs with all the info you need to use them;
https://youtu.be/wwjWXSCtsmY?si=7SGCGHsQEhuPqoZB
Jardielsilva
  • Last login:April 17, 2024, 08:29:05 pm
« Reply #1123 on: March 29, 2024, 02:40:49 pm »
Boa tarde! tudo bem?
Estou com um problema na instalação da gun4ir no windows 7, gostaria de saber se alguem ja passou por isso e poderia me ajudar.
O windows 7 reconhece o arduino pro micro, quando faço a gravação na placa, ela se tranforma em um dispositivo (GUN4IR Pro Micro P1) e o software não o detecta para fazer os testes e configurações. Segue as imagens.
Desde de já agradeço.
« Last Edit: March 29, 2024, 02:42:20 pm by Jardielsilva »
Jardielsilva
« Reply #1124 on: March 29, 2024, 07:22:17 pm »
Boa noite!
Resolvido! reinstalei os drivers.
GRA71
  • Last login:July 16, 2024, 02:37:01 am
« Reply #1125 on: March 31, 2024, 03:18:21 am »
Bonjour,
Est-ce que ce schéma est bon pour brancher un moteur de vibration <500mA, peut-on reprendre le 5V sur l'arduino ? :
Faut-il shunter le J1 sur l'Arduino Pro Micro ?
Personne ne peut me renseigner ?
Merci.  ;)
« Last Edit: April 08, 2024, 02:53:17 pm by GRA71 »
outrunner
  • Last login:April 01, 2024, 05:28:28 am
  • Replica Nintendo cab - done!
« Reply #1126 on: April 01, 2024, 05:28:28 am »
Hi, I recently setup a new old PC just for GUN4IR but the setup software doesn't seem to detect the gun. It's working as in I can move the mouse around, just the utility doesn't see any guns.
In Device manager I can see a com port appear when the GUN is connected, so I tried to install the driver from the GUN4IR folder but it reports "JB GUN4IR Pro Micro P2" "A service installation section in this INF is invalid". Any idea how I can resolve this?
Jardielsilva
« Reply #1127 on: April 17, 2024, 08:25:43 pm »
help. I don't get the output. thanks!
ar2r
  • Last login:January 13, 2025, 09:50:19 am
« Reply #1128 on: July 22, 2024, 06:24:23 am »
Hi
I have recently built a gun using arduino micro board and connected pretty much everything to it. All seams to work well but when i press right nothing happens. Button connected to pin 12 and tested on other board. I have also noticed that when rgb led is not connected the pins for directions are in different places. Is this expected? Same behaviour on all my micro boards
using firmware 2.58 - micro
with the same board in latest batocera when i press any direction I am getting double press. Have not experienced this on pro micro board. Any one seen this before?
P.S. thanks for a great project
w00master
  • Last login:September 07, 2024, 12:52:12 pm
« Reply #1129 on: September 06, 2024, 09:32:30 pm »
Hey Folks-
Just got my Gun4IR today and I've been setting it up.  For the most part, everything has been going well.  Until I tried to utilize an AHK script (I use Launchbox/BigBox) to dynamically change the resolution when you launch MAME to 3:4, then back to widescreen when you quit.  The script actually works fine, but everytime MAME launches - the window completely loses focus and I have to manually alt-tab to get to it.
Here's the script I've been using to launch when the mame rom launches in Mame:
Run, %COMSPEC% /C echo M3.1 > COM4
Run, %COMSPEC% /C echo M3.1 > COM5
~ESC::
Run, %COMSPEC% /C echo M3.0 > COM4
Run, %COMSPEC% /C echo M3.0 > COM5
ExitApp
return
Is there perhaps something wrong in my script?  Or, is there something I may be missing?  Note: in mame - I have my mame.ini file set to fullscreen.
« Last Edit: September 06, 2024, 09:34:01 pm by w00master »
POPO69
  • Last login:January 04, 2025, 01:43:29 pm
« Reply #1130 on: September 22, 2024, 06:28:27 pm »
Hello I have 2 lightgun Gun4ir. what I need for alimentation to have good FFB? actually my FFB is weak. Can I change?
