Author Topic: Aimtrak lightguns messing up Controller IDs  (Read 10186 times)
darthclem
  • Last login:July 28, 2019, 09:16:52 am
« on: July 18, 2019, 06:10:18 pm »
In my ongoing struggles to get my upgraded arcade cabinet running, I managed to get my joystick ID situation worked out, but when I went to install my Aimtrak lightguns, things got screwed up again.  It took me a while to figure out what was going on, but as I installed each of my two guns, it pushed the controller IDs of each of my UltraStiks up by 1 (so controller 1 became controller 3, and controller 2 became controller 4).  The IDs didn't change in UltraMap or under Windows USB devices -- but they did within Hyperspin and my emulators.
I tried changing the lightgun IDs in the AimTrak software, but that didn't make any difference.  If I unplug both lightguns, my UltraStiks go back to their proper IDs.
Has anyone else run into this?  If so, how did you solf it?
Titchgamer
Re: Aimtrak lightguns messing up Controller IDs
« Reply #1 on: July 18, 2019, 07:32:08 pm »
Its caused by windows reassigning the controller ID's.
Look in the lightgun forum this has been covered many times :)
darthclem
« Reply #2 on: July 19, 2019, 09:15:24 am »
Oops, my bad.
I don't want to be "that guy" who continues a thread in the wrong forum, but it seems that my lightgun issue (as well as the other post I made that probably doesn't belong in this forum on my Joystick 1 and 2 swapping) have to do with Windows USB remapping.
Given that, is the Lightgun forum still the best place to look for answers, or a different forum?  If you have any advice on search terms, that would be great, as I'm struggling to find a post with the solution.  I thought ControllerRemap might be what I was looking for, but that appears to be MAME specific and I need my Joystick IDs to be stable for all of my emulators.
« Last Edit: July 19, 2019, 10:29:33 am by darthclem »
Titchgamer
« Reply #3 on: July 19, 2019, 12:39:12 pm »
I use Tur to fix my ID’s so I would start with that :)
darthclem
« Reply #4 on: July 19, 2019, 01:00:07 pm »
Somehow I figured out the combination of IDs to assign within the Ultimarc mapping and Aimtrak software to get the controllers to fall into order.  Stick 1 is labeled Stick 2, Stick 2 is labeled Stick 3, Gun 1 is labeled gun 3, and Gun 2 is labeled gun 4.
I still snagged Tur, though, because I'd prefer to have everything labeled properly.  Thanks a ton for your help!
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
« Reply #5 on: July 20, 2019, 03:02:42 pm »
What's 'tur' and where can i get it? Searching the forum leads me to this post.
Titchgamer
« Reply #6 on: July 20, 2019, 03:11:33 pm »
Your google foo needs work young grass hopper....
Foxhole
« Reply #7 on: July 20, 2019, 03:14:59 pm »
Not really young, to be honest.
Searching google for tur leads me to all sort of places but not anything related to windows usb ids.
Can you provide a link, please?
Titchgamer
« Reply #8 on: July 20, 2019, 03:22:23 pm »
Foxhole
« Reply #9 on: July 20, 2019, 03:30:13 pm »
Sorry forgot to include it in last post :p
https://hyperspin-fe.com/files/file/11305-tur-game-controller-order/
Thank you, seems like a good program to have.
I wonder how well it works with hardware that shares the same hw id.
darthclem
« Reply #10 on: July 21, 2019, 05:40:10 pm »
I couldn't tell from the documentation (and I haven't installed it yet - busy weekend), so could someone tell me if Tur is a "run once" program or if it's something I need to put in my Windows Start-up?
Titchgamer
« Reply #11 on: July 21, 2019, 05:49:12 pm »
Needs to go in your start up.
darthclem
« Reply #12 on: July 26, 2019, 11:54:29 am »
I know that you didn't think your lot in life was to be my personal tech support, but I have an additional question  ;)
I created a shortcut to Tur and put it in my startup.  Unfortunately, it does not run (so my controllers are all out of order).  If I go into the start-up folder and click on the shortcut, it rearranges my controllers as I set them up.  Did you have to do anything special to get Tur to run on startup for your system?
Titchgamer
« Reply #13 on: July 26, 2019, 12:02:02 pm »
How strange, No I just dropped it in my start up folder.
Which OS are you running?
I did it with out any issues on Windows 7, Not sure if there is some special protocol you have to do to get it to work in 8+?
darthclem
« Reply #14 on: July 26, 2019, 04:15:20 pm »
I'm running Windows 10 (I "upgraded" my cabinet from Windows 7 when I did all the hardware upgrades).  I have the .exe set to run as administrator and I set the shortcut to run as administrator.  I tried moving the .ini file to the startup folder (which just opens it up in Wordpad when you restart).  I also deleted the .ini from the Tur folder to see if that would have any effect.
Long story, short:  Nothing I did will have Tur run at startup, yet when I click on the shortcut IN THE STARTUP FOLDER, it runs.
I'm really perplexed...  If I can't get it to launch as part of my Windows startup, I'll have to see if I get get to launch as part of HyperSpin's startup.  The program does exactly what it's supposed to do -- so I owe you a big debt for that -- I just would love for it to run on startup.
Titchgamer
« Reply #15 on: July 26, 2019, 04:29:06 pm »
Try this:
https://tunecomp.net/add-program-to-startup-windows-10/
darthclem
« Reply #16 on: July 26, 2019, 05:56:56 pm »
Try this:
I actually tried that very page before posting here, as I didn't want to be accused of having weak Google-Fu.  :)
Titchgamer
« Reply #17 on: July 27, 2019, 01:30:09 am »
Try this:
Didnt work then?
darthclem
« Reply #18 on: July 27, 2019, 09:43:40 am »
Unfortunately, no.  I saw another webpage that had 8 or 10 increasing complex suggestions.  I tried the first 5 to no avail.  My hope was that with your experience with Tur, you might have encountered something similar.
I honestly don't expect you to try to solve this for me, and I really appreciate all the help you've offered so far.  Thanks!
Titchgamer
« Reply #19 on: July 27, 2019, 09:58:54 am »
Good luck mate.
I would of stuck on Windows 7 tbh lol
darthclem
« Reply #20 on: July 27, 2019, 11:38:39 am »
Good luck mate.
In hindsight, that might have been the best decision -- but I was replacing my boot drive with a SSDD and wanted to do a clean OS install.  On the plus side, my cabinet boots almost instantly.  On the minus side are the myriad headaches that my "new and improved" OS are causing me.
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« Reply #21 on: September 15, 2019, 11:26:18 am »
Does anyone have a copy of TUR? The Hyperspin site is down.  :dunno
xbrunox
  • Last login:August 30, 2025, 05:03:06 pm
« Reply #22 on: September 18, 2019, 10:36:22 am »
Hi All TUR works if i start my cab from Power On Power OFF, but not if i start my cab from Hybernation.
personally i've solved a lot of thing with mame controller.ini file and with demulshooter.
The only emulator that i cant have with fixed ID after hybernate is supermodel. have u some solution?
thanks
