Author Topic: IPAC Ultimate I/O NOT detecting keys  (Read 2816 times)
shitoken
  • Last login:May 30, 2025, 07:41:27 am
« on: July 17, 2019, 11:27:45 pm »
Hi Friends I need your advise
My IPAC Ultimate I/O was bought in 2016-2017 cant remember exactly. I am using Win7 Ultimate SP1
I have noticed new firmware been released so I installed WinIPAC V2 and connected my board , upgraded to 1.49 i/o nogp firmware
Now the problem is green light does turn on which mean board is fine and all my RGB buttons will lit up as usually when startup computer, but it wont off till I pull the wire. Normally it will off when I start using the computer. Also the buttons stopped working I have tried typing on notepad. Dont understand what went wrong. Year back I did upgrade firmware to 1.32 without this problem all was smooth.
I can see ultimarc in device manager keyboard and I have also tried uninstalling the driver but problem still exist. All my wirings are correct and it was working on Hyperspin Just day ago. What should I do now to test further ?
My board is very less been used , because I don't play much .
Could it be winipac v2 wiped all the settings? How to reset to factory default?
« Last Edit: July 19, 2019, 03:32:44 am by shitoken »
shitoken
Re: IPAC Ultimate I/O NOT detecting keys
« Reply #1 on: July 19, 2019, 03:35:00 am »
Updates
I have checked all my default Mame keys have been wiped out after updating the firmware. Now the board have no keys been set.
How can I restore back to default Mame Keys?
