Author Topic: Wire Gauge for (Adapter Board)  (Read 1636 times)
CHRIS-F
  • Last login:October 17, 2025, 12:26:28 pm
  • I always have screws left over after repairs :-)
« on: May 24, 2019, 01:20:08 pm »
Hi Guys,
I'm making a new Jamma adapter for my City Connection pcb, I just used thick wire last time that I had lying around from an old car loom, but this time I don't have any, is there a mimimum gauge I need to use, I have some black and red which says 7/0.2 which I assume means 7 strand .2mm width? will this be ok, do I need to use thiscker wire for the power connections and if so what gauge?
Thanks,
Chris.
CHRIS-F
Re: Wire Gauge for (Adapter Board)
« Reply #1 on: May 24, 2019, 01:22:10 pm »
This is the older adapter, its working ok but it's a little loose and doesn't push all the way on, are these wires overly thick?
  • Last login:Today at 12:56:46 am
« Reply #2 on: May 24, 2019, 04:13:52 pm »
That's the same size as 24 AWG.
https://www.canford.co.uk/Technical/Article/MetricAWGWireSizeEquivalents
It's an easy size to work with, good for daisy-chain grounds and signal lines, but you'll need larger wires for the power supply connections.
20 AWG would be my first choice, but 22 AWG should work fine too.
https://www.powerstream.com/Wire_Size.htm
CHRIS-F
« Reply #3 on: May 25, 2019, 05:43:33 am »
