Author Topic: Both controllers moves together  (Read 4773 times)
heykool69
  • Last login:February 07, 2019, 02:18:33 pm
« on: January 23, 2019, 10:35:36 pm »
I'd set up my controllers in Emulation Station with my Xin Mo for two gamepads (Player 1 & Player 2) under one Xin Mo.  Whenever i started up a game.  Whatever i'd pushed or move on Player 1 side, Player 2 will move/do also.  It's like Player 1 side is controlling Player 2 controls and buttons as well.  The control settings in the Retroarch menu is correct.  User 1 and User 2 has the same mapping.
I'd even tried to use two Xin mo....one for each player.  But when i tried to set up the controllers in Emulation Station....i get input setups for GAMEPAD 3 and GAMEPAD 4, but no GAMEPAD 1 and GAMEPAD 2.
How do i correct this?  Thanks.
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
Re: Both controllers moves together
« Reply #1 on: January 24, 2019, 02:35:37 pm »
Common issue: https://github.com/RetroPie/RetroPie-Setup/wiki/Xin-Mo-Controller
I really don't get why people don't just Google first...
heykool69
« Reply #2 on: January 30, 2019, 01:33:19 am »
I'd already visited that page many times before asking here.  That page actually helped many solved the "dual Xin-Mo showing up as ONE Gamepad".  Matter of fact, I had used that line to solved the dual gamepad issue.....but not the controller moving together problems.
Update: Problem solved.  I just redid the image again...and it worked all of a sudden.
« Last Edit: February 03, 2019, 02:13:23 pm by heykool69 »
heykool69
« Reply #3 on: February 03, 2019, 02:18:09 pm »
Curious to know:   Does the Pi kept any info of my previous image in it?  Cuz sometimes my son or i wanted to try or swap a different image in it from time to time.  And if i re-insert one of my previous "working" image back in it, will it be as if i'd never removed it?  Thanks.
« Last Edit: February 04, 2019, 12:29:37 am by heykool69 »
barrymossel
  • Spectrum
« Reply #4 on: February 04, 2019, 03:08:17 am »
Yes you can swap sd cards. The image will be a snapshot of RetroPie how you left it. I actually did this: https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive The ROMs and associated data will stay on the USB drive and can be used with another image of RetroPie.
heykool69
« Reply #5 on: February 07, 2019, 02:18:34 pm »
Thanks.  I'm still trying to learn the capability of Retropie and how to move around and about.  https://retropie.org.uk/docs/
