Author Topic: JVL Conquest Software Request - itouch4  (Read 7430 times)
JoshCRT
  • Last login:April 27, 2021, 12:17:42 am
  • CRT Guru
« on: January 21, 2019, 08:50:16 pm »
I purchased an old JVL Conquest that was reporting disc read errors. The CD drive wasn't spinning, I swapped the drive but the machine still won't boot. It looks like the original operator was using a burned disc with the "MY_DISC" as the ID label - so I assume they didn't create a proper image when doing so.
Does anyone have a disc image of the iTouch 4 software? Thanks!
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
Re: JVL Conquest Software Request - itouch4
« Reply #1 on: January 23, 2019, 07:25:04 am »
Is the cd spinning after replacing the drive? Getting power?
Lowest I can find is v5. If you're interested, I can see if I have a key to go along with it
« Last Edit: January 23, 2019, 07:36:24 am by orizzle »
JoshCRT
  • CRT Guru
« Reply #2 on: January 29, 2019, 07:23:38 pm »
The replacement drive is indeed working, I tested it with an IDE to USB adapter and was able to read the disc fine on another PC.
I can hear it spin up and start being read, it shows the disc ID at the bottom of the screen (MY_DISC) so I know it sees the disc. Before replacing the drive it never saw the disc ID.
Knuthildchen
  • Last login:October 22, 2021, 07:04:55 pm
« Reply #3 on: January 21, 2021, 04:41:04 pm »
Hi,
still in need of this software.
I have iTouch4PLUS V2.0X TW
Just let me know if you still want it.
And let me know to which place I could upload it.
It is 360MB
Best Regards
