Author Topic: hard drive failed on mega touch now I have error  (Read 7535 times)
Drakin
  • Last login:December 10, 2022, 12:51:42 pm
« on: January 21, 2019, 08:13:56 am »
Any suggestions....Thanks
Sorry the last picture is kida hard to see.
« Last Edit: January 21, 2019, 08:15:28 am by Drakin »
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
Re: hard drive failed on mega touch now I have error
« Reply #1 on: January 21, 2019, 08:19:43 am »
You have a Force machine that's being recognized as a Maxx. This generally means your ioboard is not being detected. There have been numerous forum posts about this
Sent from my XT1687 using Tapatalk
Drakin
« Reply #2 on: January 21, 2019, 08:59:33 pm »
Yea....I've looked at those posts....I have unplugged the I/O board but still have the error...I never get the I/O board error....all 4 led's light up...I've re-installed the os many times with no luck.
Anyway I'll try a few more things...
Drakin
« Reply #3 on: January 21, 2019, 09:24:20 pm »
There isn't a "key" on the I/O board....Is there  supposed to be one?
orizzle
« Reply #4 on: January 23, 2019, 07:23:06 am »
Assuming this is a Fusion? Key will be in the ioboard or on the opposite side of the monitor on the osd board. From your pictures, it appears to be in the osd board
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
« Reply #5 on: January 23, 2019, 08:13:15 am »
If you pull the key out of the osd board, do you get a "no key detected" error? Im wondering if your key's battery died. Also try taking the key out of the osd board and put it in the IO board to rule out bad wiring going from the osd to IO.
Drakin
« Reply #6 on: January 23, 2019, 07:43:43 pm »
Thanks for the reply...Ill try that...thnx
orizzle
« Reply #7 on: January 23, 2019, 10:41:11 pm »
Is your key SA3526? That's Force 2007. You have a 2004 hard drive judging by the error message.
Drakin
« Reply #8 on: January 26, 2019, 04:59:51 pm »
Ok I dont get an "no key detected" when removing key. Key is a SA- 3579
The Hard drive in the picture had died so I'm using a Hitachi DeskStar 30gig
« Last Edit: January 26, 2019, 05:01:50 pm by Drakin »
Drakin
« Reply #9 on: January 26, 2019, 05:05:45 pm »
So a SA-3579 key is for Force 2010 right? is this system capable of running that and the bios boot screen says FORCE 2003.
mahkeymike
« Reply #10 on: January 26, 2019, 05:19:40 pm »
What version did you install on this hitachi hard drive? Or did you buy it with software installed?
Drakin
« Reply #11 on: January 26, 2019, 05:34:44 pm »
I had installed 2004 ... in the process of getting the 2010 version...I'll install that and let you know what happens.
Thanks for the help btw.
« Last Edit: January 26, 2019, 05:39:26 pm by Drakin »
orizzle
« Reply #12 on: January 26, 2019, 05:49:37 pm »
Just when I thought I'd heard of everything
mahkeymike
« Reply #13 on: January 26, 2019, 05:59:13 pm »
Make sure you get 2010 force not 2010 ion. You are looking for this image: V28_20T100329_1757_1OF1
Drakin
« Reply #14 on: January 27, 2019, 11:56:26 am »
Alright game is up and running!....thanks for the help...always a learning experience.
Probably an easy fix for somebody that has worked on allot of these...I was figuring it was something more than just a simple correct OS install.
I know now to look closely at the key regardless of what the splash screen says. :)
« Last Edit: January 27, 2019, 11:59:02 am by Drakin »
