Author Topic: Coin Door Wiring Sparks  (Read 9216 times)
Csdoplr
  • Last login:December 03, 2018, 10:31:13 am
« on: December 03, 2018, 09:50:05 am »
Hello all,
New to pinball restoration and I have a issue. I have a Bally EM Bow and Arrow Machine. The coin door I recently rewired. However on the second coin micro switch that I reconnected now sparks and burns when I hit the credit button on the game and smokes everywhere. The micro switch that I attached thr wire too had a bit of a broken connector but I am still able to solder it and get a connection. I believe it is starting to make the other two wires connected to the three wire micro switch burn and smoke as well. Does anyone know why this would be? I am not sure if its becasue the micro switch has the connector missing or if it is something else.
Titchgamer
Re: Coin Door Wiring Sparks
« Reply #1 on: December 04, 2018, 03:41:30 am »
If the connection is broken or cracked it will increase resistance, pull more current and get hot.
