Author Topic: system shut down :-(  (Read 5326 times)
Gary.payne
  • Last login:October 28, 2018, 04:23:59 pm
« on: October 19, 2018, 11:07:43 am »
Hi guy's,
I've just got another megatouch it's the XL platinum and it's got the system shutdown problem, I've tried the del.nvram fix and it hasn't worked probably because this one is booted up from a cd rom rather than a hard drive
can anyone help me clear this?
Gary
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
Re: system shut down :-(
« Reply #1 on: October 19, 2018, 11:19:12 am »
Post a screenshot of what you're seeing. Does it give you the option for a PIN?
Gary.payne
« Reply #2 on: October 19, 2018, 01:10:12 pm »
This is what I'm getting I've tried clearing the memory with the set up and calibration buttons
Gary.payne
« Reply #3 on: October 19, 2018, 01:11:16 pm »
no option for a pin just goes straight to this screen
orizzle
« Reply #4 on: October 19, 2018, 02:13:10 pm »
Anything happen if you tap the screen a few times?
You may want to try a 2 button clear as described here:
http://www.meritgames.com/Support_Center/manuals/Megatouch%20XL%20Technical%20Service%20Manual.pdf
· Two Button Clear:
1. Turn game power off.
2. Remove the coin box/bill acceptor.
3. Depress and hold the Calibrate and
Set-up buttons located in the rear of
the coin box opening.
4. With Calibrate and Set-up depressed,
turn game power on.
5. Release Calibrate and Set-up buttons
when “2-Button Clear Detected” is
displayed on screen.
6. “2-Button Clear Complete”
· Using the diagnostics software, run the
“Motherboard Tests,” “Processor Test”
and “Co-Processor Test” to make sure
they are each working correctly
« Last Edit: October 19, 2018, 02:42:04 pm by orizzle »
Gary.payne
« Reply #5 on: October 19, 2018, 04:27:35 pm »
Ran the diagnostics and the only failure I had was the speaker test??
orizzle
« Reply #6 on: October 19, 2018, 06:36:25 pm »
So I'm guessing you're up and running if you can get to the diagnostics?
Gary.payne
« Reply #7 on: October 21, 2018, 08:00:02 am »
No it was still showing shut down error I've run the diagnostics again and now it's telling me I have a fault on the cd rom, so I'm going to try and replace it and try again from there
Thanks for your help so far, I'll be back when I've sorted out a replacement cd
orizzle
« Reply #8 on: October 21, 2018, 07:28:54 pm »
I can send you an iso to burn your own if interested
Gary.payne
« Reply #9 on: October 28, 2018, 04:23:59 pm »
Hi Orizzle,
I don't think it's the cd disc, I think it's the actual player where the fault lies, I've tried a couple of different cd players and I think I might have narrowed it down to the ribbon cable, just trying to get hold of a replacement off an old computer I have knocking around somewhere
thanks
Gary
