Author Topic: Generic USB joystick board - how to connect?  (Read 8995 times)
drabina
  • Last login:September 13, 2018, 04:28:58 pm
« on: September 09, 2018, 03:28:09 pm »
I have a cheap generic USB board that came with my joystick and buttons. There are few K ports (K1-K4 and K11-K12) but some are labeled as TURBO, AUTO, CLR, MODE, AU, AR, AD, AL, ST, SE, R1, R2, L1, L2. My arcade has 1 joystick, 6 buttons on the control panel plus 3 buttons on the front panel. How do I connect everything? I am installing Recalbox on the Raspberry PI 2 to run the arcade. Does it matter which ports on the USB board I use or is all configured later in the software?
Titchgamer
Re: Generic USB joystick board - how to connect?
« Reply #1 on: September 09, 2018, 04:01:53 pm »
JDFan
« Reply #2 on: September 09, 2018, 05:23:50 pm »
Upper left connector is for the USB cable that came with it to go from the board to your PC USB port
Joystick depends on if you have a 5-pin connector or 4 2 pin connector type - If 5 pin it goes into the 5-pin port to the right of the USB connector Or if 4 2 pin connectors they go into the 4 2 pin connectors to the right of that ( AU is Up , AR RIght, AL Left, AD down ) for the joystick directions.
THen for your Buttons those are the 12 2 pin connectors along the bottom - SO that is where you connect the 6 CP buttons and 3 front panel buttons ( then you set them up in MAME or what ever emulator you are using )
drabina
« Reply #3 on: September 10, 2018, 08:19:54 am »
Thanks! Got the USB controller working. Originally, I had the TURBO, MODE, etc buttons connected but after reading your replies, I have switched them to the lower part of the ports and was able to configure all the buttons in RetroPie.
