Author Topic: JVL Retro Interface board battery  (Read 6490 times)
mshort520
  • Last login:June 01, 2018, 04:47:32 pm
« on: May 25, 2018, 07:03:47 pm »
I have a JVL Retro that threw the "interface board battery is low" message. I soldered in a new battery, but I still get the same message. The new battery measures 3.66 volts with the machine running or off. Have any of you seen this problem? Thanks
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
Re: JVL Retro Interface board battery
« Reply #1 on: May 28, 2018, 09:44:49 am »
Did you try doing a factory reset after you replaced the battery?
mshort520
« Reply #2 on: May 29, 2018, 11:35:55 am »
No I didn't. How do I perform a full factory reset?
mahkeymike
« Reply #3 on: May 29, 2018, 03:07:09 pm »
press and hold the yellow setup button during boot up till it goes to the factory reset screen.
mshort520
« Reply #4 on: May 29, 2018, 03:38:53 pm »
That's what I thought but when I hold in the yellow set up button, then turn on the machine, then continue to hold it , the machine just boots up normally. When the machine is on the set up button operates as it should. Tried it 4 times in a row and it always booted up normally. ???  I'm running itouch 10+
mahkeymike
« Reply #5 on: May 29, 2018, 07:53:00 pm »
Maybe the Interface board is faulty? I have had the low battery issue, and even after replacing with another 3.6v battery, got the same message, but after a factory reset the error was fixed.
mshort520
« Reply #6 on: May 29, 2018, 08:28:44 pm »
Finally got it to reset (just kept trying) and now the error message is gone.  :applaud:  Thank you  for the help.
mahkeymike
« Reply #7 on: May 29, 2018, 08:40:11 pm »
You are welcome. :cheers:
