Author Topic: Mala pass %path% to command when using Gamelists  (Read 6637 times)
Jakobud
  • Last login:April 28, 2025, 12:29:02 am
« on: May 16, 2018, 03:18:37 pm »
I have my Mame command line in Mala set to this:
%rom% %path%
I have it setup this way so that I can use other Emulators in the "All Games" list (there is another thread about that topic). I've noticed that this works great when using the "All Games" list in Mala. But if you are using any other sort of custom gamelist, it does notwork because Mala does not appear to pass the %path% to the command. It only passes the %rom% name.
Can anyone verify this or does anyone know how to fix this?
Jakobud
Re: Mala pass %path% to command when using Gamelists
« Reply #1 on: May 19, 2018, 08:48:01 pm »
FYI I solved this issue. I was using Romlister to generate Mala gamelist files. But Romlister doesn't have a way to specify the path of each game. So it just leaves it blank, which is why I was not getting the path for any games that were being launched.
empardopo
  • Last login:June 20, 2025, 01:05:44 pm
    • My personal forum
« Reply #2 on: May 20, 2018, 04:16:23 am »
I think you can check it activating the log in mala.
%rom% %path%
Enviado desde mi MI MAX 2 mediante Tapatalk
