Author Topic: First Cabinet Build: I have no idea what I'm doing  (Read 120420 times)
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
Re: First Cabinet Build: I have no idea what I'm doing
« Reply #40 on: May 16, 2018, 05:32:26 pm »
The angle of your sides means you will have a bottom marquee that has a lot of dead space in it (unless you plan on putting large speakers in it).
What do you mean by this?
obizues
« Reply #41 on: May 16, 2018, 10:11:58 pm »
New updated 3-D rendering, which I should be able to dissemble and make a 2-D image for CNC machining.
  • I changed the size to better suit by own height
  • Rounded out the corners
  • Added a more dramatic cut in the profile pieces
  • Filled in the front and back with slots to access the cab
  • Added 32" LCD holder (at 20 degree angle) to create a bezel for the viewing area.
  • Tilted down the control panel 10 degrees.
  • Added speaker cuts
  • Added more depth to the control panel's depth for buttons and stick housing
  • Made more space for wrists to rest on from edge.
Feedback is encouraged and welcomed!
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
« Reply #42 on: May 17, 2018, 03:44:27 pm »
Don't worry about it. In your new rendering I can see what you did more clearly. However that brings up another concern. Your marquee box's bottom panel looks as if it might interfere with the top of your speakers on your speaker panel. Have you checked for clearance?
obizues
« Reply #43 on: May 17, 2018, 03:45:59 pm »
I’m removing the back piece of wood in the marquee altogether based on a recommendation by another person. So I should have plenty of room for the speakers now. ;)
ivwshane
« Reply #44 on: May 17, 2018, 03:48:34 pm »
Can you post a side view of the cab? I'm concerned that the overhang of your cp would create a tipping hazard. On a slim cab I built that was an issue and my cp didn't overhang anywhere near as much as yours appears to be.
obizues
« Reply #45 on: May 17, 2018, 03:51:01 pm »
ivwshane
« Reply #46 on: May 17, 2018, 03:58:32 pm »
Its hard to say, it may or may not be an issue.
Worse comes to worst, you can put it on pedestal (essentially just a sheet of mdf that sticks out far enough to not allow tippage when playing hard.
obizues
« Reply #47 on: May 18, 2018, 11:19:59 am »
Updated my CP design to get rid of a bunch of admin buttons down to just 2 (Pause and Exit), and removed dedicated 4-way and flyleaf buttons.  Also removed spinner.  Also removed 1 of my 1p and 2p buttons, and moved one down to fit a more "Neo Geo" style.
Down to 37 buttons, still too many to fit on Ultimate I/O.
I wanted to put all the buttons on a different RGB, but maybe it makes sense to chain the Player/Coin and Exit/Pause buttons together?  Thoughts anyone?
obizues
« Reply #48 on: May 18, 2018, 11:29:42 am »
Or is this better?  I moved up the 1p-2p and trackball and brought the front end of the control panel up as well (all 44mm.)
  • Last login:September 29, 2024, 10:43:33 pm
  • Bitches love Centipede
« Reply #49 on: May 18, 2018, 11:35:54 am »
Are you sure you're counting right? There are 37 holes in that CP, but only 32 of the holes are for buttons... Advice you won't take: 6 buttons for players 1 and 2, not 7.
%Bartop
obizues
« Reply #50 on: May 18, 2018, 11:40:53 am »
Sorry, I'm counting the joysticks and the ball that will be illuminated as well.
And yes, I do want to keep the 7 buttons for neo geo.  Those are some of my favorite games.
« Reply #51 on: May 18, 2018, 11:45:17 am »
NeoGeo layout is 4 buttons, not 7. Most NeoGeo games don't even use all 4. Do you really need RGB LEDs for all the controls? No. Coin buttons (even though you shouldn't have any, get a coin door) don't need to be every color of the rainbow, and neither do your admin buttons (hell, hide those under the CP and they don't even need to be lit up).
%Bartop
  • Last login:Today at 06:11:56 pm
« Reply #52 on: May 18, 2018, 11:46:53 am »
Not sure I understand.  Neo Geo only uses 4 buttons max... Most people use the top row and the left button on the bottom row to get the arc.
obizues
« Reply #53 on: May 18, 2018, 11:56:20 am »
Of course I don't "NEED" them.
On that topic, where can I find a 4-person coin door?
obizues
« Reply #54 on: May 18, 2018, 11:58:09 am »
I did think about that, but it just doesn't feel right.
« Reply #55 on: May 18, 2018, 12:07:10 pm »
I find it mildly humerous how you went from wanting an inexpensive, single color, LED setup to completely off the deep end with this. And as someone who has done almost exactly what you're describing now... Don't do it.
%Bartop
  • Online Online
  • Last login:Today at 07:31:40 pm
luizw81
  • Last login:December 05, 2022, 12:39:36 pm
  • I love the Power Glove. It's so bad.
« Reply #58 on: May 18, 2018, 03:02:16 pm »
This 2nd one looks better.  You could probably that the front end off completely, actually.
And I know what you mean about the Neo Geo controls.  My current panel has the Street Fighter 6 button style and it feels unnatural playing Samurai Showdown.  No idea why some of us get up in arms about one extra button...
Sent from my SM-J320R4 using Tapatalk
obizues
« Reply #59 on: May 18, 2018, 03:05:58 pm »
I was thinking about that.. but it would look a little too curvy for me.   :dunno
obizues
« Reply #60 on: May 18, 2018, 03:13:34 pm »
Okay, last draft before I lay all the pieces down and create a .DWG file for it to be CNCed.
Any final input?
1)
2)
3)
4)
  • Last login:Today at 03:47:02 pm
« Reply #61 on: May 18, 2018, 03:33:09 pm »
I hope you plan on strapping that thing to a wall. That giant, heavy control panel is hanging out way past the center of mass.
obizues
« Reply #62 on: May 18, 2018, 03:56:20 pm »
How have others solved this problem?  Extend the front?  I just don’t want to make a podium.
« Reply #63 on: May 18, 2018, 03:59:24 pm »
Look at how actual arcade machines are designed.
Sent from my Pixel using Tapatalk
obizues
« Reply #64 on: May 18, 2018, 04:04:34 pm »
 It’s obviously a lot different with a much larger control panel. I can move the control panel further into the machine but only so much until it hits the display.
« Reply #65 on: May 18, 2018, 04:05:51 pm »
Maybe there is reason they are not built that way.
« Reply #66 on: May 18, 2018, 04:08:09 pm »
Any final input?
Before you cut a piece of wood for this project. Start and finish a mini project first. Build a 1 player stand alone CP with the layout you want to use in the bigger project. Play on that for a while before cutting bigger, more expensive pieces. Once you're happy with a layout or control setup you like, then cut the big pieces and transfer your controls over to the big project. You've changed your mind many times this week, and I dont think you're done yet.
%Bartop
  • Last login:September 14, 2024, 08:17:47 pm
« Reply #67 on: May 18, 2018, 04:08:36 pm »
Mike and the others who have painted it out are right - your CP looks like it’s going to fall off. Extend the bottom out some more to cradle the panel.
obizues
« Reply #68 on: May 18, 2018, 04:12:34 pm »
Arroyo
  • Last login:September 09, 2024, 07:55:57 am
  • Budgets are boring
« Reply #69 on: May 18, 2018, 04:20:37 pm »
Make sure you’ve accounted for the depth requirements of the trackball.  The control panel housing depth may be an issue.
obizues
« Reply #70 on: May 18, 2018, 04:52:08 pm »
Yeah the crappy part is my buttons are being restocked right now...  :badmood:
obizues
« Reply #71 on: May 18, 2018, 04:52:37 pm »
This should be fine,  I have 3 1/2 inches and the trackball only needs 2"
« Last Edit: May 18, 2018, 07:14:07 pm by obizues »
« Reply #72 on: May 18, 2018, 05:01:27 pm »
Dude, when I built the Beast, I had to buy black buttons and transparent buttons and make my own. There was no off the shelf like that. And if you wait around for Paradise... Well, it'll be a long ---smurfing--- time.
Funny, they have both black and transparent in stock... You're just waiting on them to swap plungers...  :laugh2:
« Last Edit: May 18, 2018, 05:05:43 pm by Nephasth »
%Bartop
vwalbridge
« Reply #73 on: May 18, 2018, 05:45:40 pm »
Didn't have time to read the whole thread but this looks like a great start to having a nice aircraft carrier.
barrymossel
  • Spectrum
« Reply #74 on: May 19, 2018, 04:20:36 am »
FFS http://bfy.tw/ICvW
obizues
« Reply #75 on: May 19, 2018, 05:23:50 pm »
:laugh2: Some people have a hard time with newbie questions, especially in a thread titled “I have no idea what I’m doing.” :laugh2:
That being said, I know I can google and find a used one, a new one, etc. I don’t know if there are some with different wiring or changeable options which limit what I should be using for a MAME machine.
IE: you wouldn’t tell a person who wants to create a Pac-Man feeling arcade to just buy any joystick and button after googling it. You would tell them to make sure to buy a 4–way balled shorter stick with a flyleaf gold leaf button.
Get it?
luizw81
« Reply #76 on: May 19, 2018, 08:07:18 pm »
obizues
« Reply #77 on: May 19, 2018, 08:56:58 pm »
I went to FedEx to print out my CP drawings to make a test unit.  Sadly Sketchup exported a PDF and PNG both different sizes, and neither of them correct.
I’ll be bothering their forum for answers tonight, since only EPS you can mark to export to 1:1 size, but FedEx does not accept that format.  I find it strange the other exports wouldn’t allow this option.
  • Last login:October 27, 2024, 03:40:35 pm
« Reply #78 on: May 19, 2018, 09:07:37 pm »
I hope some little kid doesnt jump up and hang from the center 2 sticks or else you you'll have to use their college fund for funeral expenses.
I was never a fan of the cab you based this design on, and you somehow found a way to make it worse by making it thin profiled.  Have you considered a more NBA Jam shaped control panel? Hope you have great medical insurance too, so you can get carpal tunnel surgery from that CP angle after you're done burying children.
obizues
« Reply #79 on: May 19, 2018, 09:26:41 pm »
Besides the much appreciated well-wishes for my health and finances, which part of the NBA Jam CP are you referring to?  That it's rectangular or there is "more" space in your opinion for your hands/arms than mine has to properly rest on?
I can from images the NBA Jam CP is taller so it would only result in forearm surgery or taller kids hanging from the center sticks, so is that what you mean?  Or is there a single shotgun blast that fires when someone does that on the NBA Jam cabinet I have forgotten?
