Author Topic: Using 480p with Multiformat PVM  (Read 12206 times)
Yardley
  • Last login:July 22, 2025, 11:36:15 pm
« on: May 02, 2018, 11:07:35 pm »
Hi guys, I have a PVM-20L5 which supports 480p, 720p and 1080i. I am trying to get 480p working to use with PCSX2 for games that support it. After reading a few posts on here I went into VMM and changed the monitor preset to the Arcade 15/31 kHz dual-sync monitor. I also edited my .ini and added the line 640 x 480 @ 60.000000. After making these changes, I can see 640x480 60P in Arcade OSD and I can select it and other than some geometry issues it looks ok however the windows desktop when set to this resolution doesn't display properly and neither does PCXS2. Here's a picture, what I'm I missing?
buttersoft
  • Last login:Today at 01:01:32 am
  • Is running at 15kHz
Re: Using 480p with Multiformat PVM
« Reply #1 on: May 03, 2018, 12:36:45 am »
Do you mean the streaky lines on the side of everything? I want to say it's possible that's caused by porches. Try bringing the sides of the image in with ArcadeOSD and see what happens?
After that, this kind of streaking problem isn't uncommon. What happens with sources other than a PC, both 15kHz and all the way up to 720p, does it do the same thing?
Yardley
« Reply #2 on: May 03, 2018, 12:47:40 am »
That and everything else, the black that you see is part of it too. It’s fine on 15kHz with the PC. About ArcadeOSD, I tried to tweak the geometry but I don’t understand how it works. I couldn’t see any change in size after tweaking the parameters.
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
« Reply #3 on: May 03, 2018, 06:19:20 am »
Yes, the horizontal front porch is probably too low.
You can't edit the current desktop resolution. Set a different one for the desktop, then you'll be able to edit the previous one with Arcade OSD.
Steps to create a log:
Yardley
« Reply #4 on: May 03, 2018, 01:57:36 pm »
Thanks for the suggestions guys. I tried some things but got nowhere. I am pretty lust to be honest. Here what I did: in ArcadeOSD I selected video modes, and pressed enter on 640 480 60p 31.498 KHz. The PVM flashes and splays 480/60P. I went to Horizontal Geometry and tried increasing the H front porch from 1 through 31 and then random higher numbers after that but I didn't see a difference. On the button where it shows what the different keys do, what is [P2]?
buttersoft
« Reply #5 on: May 03, 2018, 09:02:11 pm »
To reiterate what Calamity said, you're not allowed to be using the mode you want to adjust. If your desktop is set to 640x480 you cannot edit that mode while in ArcadeOSD, so set the desktop to something else. Also, I believe you can't edit modes the EDID emulation sets. If you enable a single mode via EDID emulation it will be 640x480@30, i think it is, so you often have two 640x480 modes in the list, one of which can't be altered.
Setting the front porch higher would normally move the right-hand side of the visible picture inward. The back porch is the left side, and more likely to help this issue. (EDIT: don't know where I got that from, given calamity says the opposite, above?)
I can't for the life of me think what [P2] is. I'll have to go check :) How many monitors are you using at once, just the PVM or an LCD too?
« Last Edit: May 03, 2018, 11:53:05 pm by buttersoft »
Yardley
« Reply #6 on: May 03, 2018, 09:25:09 pm »
I do have an LCD connected along with the PVM. About not using the resolution I am trying to edit, I caught that from Calamity's response but when I select the resolution I want to edit in ArcadeOSD doesn't the desktop resolution switch to that automatically?
buttersoft
« Reply #7 on: May 03, 2018, 11:01:10 pm »
Windows probably protects what it has recorded in the registry as the desktop, so until you tell windows to switch, you're only altering what you're looking at, not what windows records as the desktop. Just a guess.
Are you targeting the right display with both VMM for EDID emulation and then with ArcadeOSD? You could test this with the arcade_15 preset in VMM, because the LCD probably won't like that. So set that preset and enable EDID emulation, then without adding any modes, in ArcadeOSD hit the "2" key, the number key, to switch displays, and the "1" key to lock to current display if needed. Make sure ArcadeOSD is on the PVM and locked to it. Then you should only be seeing the 640x480 interlaced mode the EDID specifies in the modelist, all other other modes should be greyed out. If that's not the case then you're not targeting the right display, or using the right video port on your GPU.
Apologies if this is taking you back a few steps with these posts, just trying to get a handle on what might be wrong :) What graphics card are you using, by the way? And how is it cabled? And do other 480p sources look the same?
tisurame
  • Last login:August 03, 2025, 10:50:53 am
« Reply #8 on: May 04, 2018, 10:27:04 am »
Maybe it's also a sync issue?
I'm really not sure. I also have a PVM-20L5 and remember to have the same problem. Please, let us know if you fix it.
Calamity
  • Moderator
« Reply #9 on: May 04, 2018, 01:21:36 pm »
No, it just enabled the resolution temporaly, it's not a permament setting, like when you do it from the screen properties Windows dialog.
cyb
  • Last login:December 19, 2025, 04:07:20 pm
« Reply #10 on: May 08, 2018, 06:48:24 pm »
How do you have your PC connected to the PVM? How are you combining sync? When I had a 20L5 I had a similar issue with Dreamcast VGA. Someone one here suggested using an Extron Sync Stabilizer (ss200) and that fixed all of my problems.
Yardley
« Reply #11 on: May 08, 2018, 07:32:28 pm »
VGA to RGB using the composite sync feature of CRT Emudriver. I took a look at the Extron, looks like its RGBHV in and out? Do you also use composite sync through CRT Emudriver or are you using something else?
cyb
« Reply #12 on: May 08, 2018, 07:55:57 pm »
It's been several years since I used it but at that time groovymame did not support composite sync so I used RGBHV, but the device was able to output composite sync. An extron RGB rxi/xi interface might work better in this scenario now that I think about it.
buttersoft
« Reply #13 on: May 08, 2018, 10:00:56 pm »
If you're not scaling you could even try an extron 190F, those tend to be a tad cheaper.
Yardley
« Reply #14 on: May 09, 2018, 12:52:34 am »
Thanks guys. Just so I understand this correctly, I would connect the PC to the Extron through VGA, then go out to the PVM through RGBs from the Extron and I would disable composite sync in CRT Emudriver since the Extron is taking care of combining the sync?
How do these Extron devices fix the issue with 480p? Buttorsoft, not scaling meaning adjusting the size vertically and horizontally? It would actually be nice to be able to do that so I wouldn't mind paying a bit more.
buttersoft
« Reply #15 on: May 09, 2018, 01:11:43 am »
Well, cyb is saying he had an issue like this with a PVM-20L5 and was able to fix it using an extron unit. And Calamity was saying it looked like a front porch issue, which is sync-related as well. I'm not sure if this will work for you or not, but if you don't want to try recombining sync for yourself with a breadboard, some breakouts and a pack of resistors, then getting an extron isn't a bad idea. Extron make many different devices, and used to make tons more, and many of them are really good at combining sync, doing so very cleanly.
Yes, it would be PC ---> VGA cable ---> Extron ----> 4 BNC cables for RGBS (or RCA+adapters) ---> PVM-20L5
The 20L5 will take 480p via RGBS happily.
I meant not scaling as in not upscaling or downscaling, keeping the same resolution and timings. So with the extron 190F you feed 480p in, and 480p comes out, or 720p for 720p, etc. ignoring any signal formats here. Obviously you're converting RGBHV to RGBS in this case too, and there is a function for horizontally shifting the picture, so remember to try this out as it might help fix things too. The extron 201 and 203, IRC, are taking whatever you feed in and turning it into 240p/480i. Or they can do that but don't have to? Either way they cost a bit more and you might be paying for something you don't need. That said, take a look at those units and see if they're doing something you might want. It's worth looking up the documentation for any extron you're thinking of buying to check it out, most of them would be pretty cool to have in general.
If you do grab one, report back with results please :)
« Last Edit: May 09, 2018, 01:23:57 am by buttersoft »
Yardley
« Reply #16 on: May 09, 2018, 01:21:40 am »
Thanks that makes sense. And being able to adjust the image horizontally is what could possible fix my problem?
buttersoft
« Reply #17 on: May 09, 2018, 01:39:02 am »
possibly, yes. It might even be that cleaning up the sync generally does it, but shifting horizontally might help. Be aware that this might introduce a tiny delay, and thus video lag, but it shouldn't be too bad.
I should probably edit the above post though, because the 203rxi units look to be bigger, better versions of the 190F, with audio passthrough and an internal power supply where the 190F can be a bit sensitive to its external one.  They even have vertical position adjustment, which might help as well. And they don't seem to scale anything either.
« Last Edit: May 09, 2018, 01:43:57 am by buttersoft »
Yardley
« Reply #18 on: May 09, 2018, 10:25:12 am »
Thank you very much.
buttersoft
« Reply #19 on: May 28, 2018, 10:46:36 pm »
Yardley
« Reply #20 on: May 31, 2018, 01:00:12 am »
Some possibly-related info here - https://shmups.system11.org/posting.php?mode=reply&f=6&t=62541
Thanks! I will try it and report back once I do so.
buttersoft
« Reply #21 on: August 12, 2018, 10:55:32 pm »
Did we get a result or fix for this?
EDIT: looks like someone did, anyway.
Go into the service menu and change Y-CLMP to a higher or lower number so it is no longer sampling clamping values during the active picture. No need for the extron device.
...navigate over to this post on shmups https://shmups.system11.org/viewtopic.php?p=1318978#p1318978
The post I specifically linked mentions changing a value within the 20L5's service menu (different than the normal menu) called "CLP P DLY",  mine was at 200, i started to increase it's value from 219-220 there was a black and white difference in the streaking/discoloration problem, I decided to leave mine a healthy dose over at 230.  Hopefully that solves the issue, forever!
For any future readers, to access the service menu, click the normal menu button on the right side panel, then once it's open click ENTER + DEGAUSS simultaneously.  The "CLP P DLY" value is located within the "LEVEL-1" menu entry
« Last Edit: August 13, 2018, 07:38:29 pm by buttersoft »
Yardley
« Reply #22 on: August 15, 2018, 02:00:47 pm »
Thank you! This worked perfectly. I have a question, I was trying to add a 1280 x 720 modeling so that I can adjust settings in PCSX2 since it hard to do so at 480p, I added 1280 x 720 @ 60.000000 to my ini and generated/installed the new modelines but 720p doesn't seem to stick. Any idea why?
buttersoft
« Reply #23 on: August 15, 2018, 07:15:01 pm »
Might be because the range settings you picked in VMM, from the monitori.ini file, don't go high enough to allow a 720p modeline? Did you pick one of the presets, or make your own? There are some multiformat BVM range settings in the monitor presets sticky on here, so those might give you a leg up if you can't google something specific. Take a read of the presets sticky though, as it explains how range lines work.
I'd get the above sorted first, beause using your monitor's potential is great, but if you have EDID emulation enabled, you can always just plug an LCD into another port on your GPU at the same time, and it should be fine to configure things. Or rotate the 480p desktop so you can see more, mb.
« Last Edit: August 15, 2018, 07:16:35 pm by buttersoft »
