Author Topic: Problems with Ati HD5570  (Read 6275 times)
zerozerosette
  • Last login:July 09, 2018, 10:40:19 am
« on: April 16, 2018, 09:12:58 am »
Hello
(I am not sure this the right section, sorry if it is not) I'm having problems with this card
https://www.amd.com/en-us/products/graphics/desktop/5000/5570
My card is slightly different, as it hasn't the VGA connector (instead it has a displayport connector) so I'm using a dvi to vga converter. Installation of crt emudriver went fine - I followed the tutorial for newer cards - but when I try to enable EDID emulation my arcade monitor shows the windows desktop for less than a second, then the image starts to flicker (I think the signal switches back to 31khz). Could the dvi to vga converter be a problem? Any ideas?
Thank you very much!
B2K24
  • Last login:June 10, 2025, 10:17:56 am
Re: Problems with Ati HD5570
« Reply #1 on: April 16, 2018, 10:16:18 am »
Buy another card. They're creap.
VGA or don't bother with it.
Calamity
  • Moderator
  • Last login:February 19, 2026, 06:15:36 am
  • Quote me with care
« Reply #2 on: April 16, 2018, 11:11:19 am »
Hello
There are 2 analog outputs configurable in VMMaker. Make sure to point to the right one for EDID emulation.
Steps to create a log:
zerozerosette
« Reply #3 on: April 16, 2018, 11:34:39 am »
Thank you, I just needed some encouragement  ;D
Any suggestions?
« Last Edit: April 16, 2018, 11:37:55 am by zerozerosette »
zerozerosette
« Reply #4 on: April 16, 2018, 11:37:09 am »
Hello
First of all, thank you for crt_emudriver  :)
I tried changing the outputs and I think I'm using the right one (I am using output 0, if I use output 1 nothing happens)...
Calamity
  • Moderator
« Reply #5 on: April 16, 2018, 12:54:09 pm »
Try to figure out what's being output. You said you think it's 31 kHz. That should be pretty easy to determine. Plug a pc monitor, check its osd, etc.
« Last Edit: April 16, 2018, 01:36:43 pm by Calamity »
zerozerosette
« Reply #6 on: April 16, 2018, 04:22:01 pm »
Yes, it appears its 31khz as I can see my desktop on my lcd monitor. I don't really know where to look to debug this issue...
Here is my configuration:
https://drive.google.com/open?id=1ZsCT9YwhSN3stmGl3yLtOtqqRUkW7bkH
And osd:
https://drive.google.com/open?id=1G56cGFBNTI6A5Rpq5Pn9i-AadPuqrzli
Calamity
  • Moderator
« Reply #7 on: April 16, 2018, 04:26:33 pm »
How are you connecting your LCD?
zerozerosette
« Reply #8 on: April 16, 2018, 04:42:14 pm »
The first screen is from HDMI, the second one from VGA (the monitor is the same).
Calamity
  • Moderator
« Reply #9 on: April 16, 2018, 04:52:24 pm »
In VMMaker, video card tab, "device" dropdown, one of the entries should have the "GENERIC_15" label, is that the case?
zerozerosette
« Reply #10 on: April 16, 2018, 05:07:23 pm »
No, it's generic nonPnp monitor  :-(
Calamity
  • Moderator
« Reply #11 on: April 25, 2018, 02:33:59 pm »
Then maybe it's just EDID emulation not working on your card. This doesn't mean you can't use that card, it's only less convenient as Windows will detect the monitor as non-PNP. Just create the modes and install them, it will probably work anyway.
