February 25, 2026, 07:21:30 am
Hello(I am not sure this the right section, sorry if it is not) I'm having problems with this cardhttps://www.amd.com/en-us/products/graphics/desktop/5000/5570My card is slightly different, as it hasn't the VGA connector (instead it has a displayport connector) so I'm using a dvi to vga converter. Installation of crt emudriver went fine - I followed the tutorial for newer cards - but when I try to enable EDID emulation my arcade monitor shows the windows desktop for less than a second, then the image starts to flicker (I think the signal switches back to 31khz). Could the dvi to vga converter be a problem? Any ideas?Thank you very much!
Buy another card. They're creap.VGA or don't bother with it.
Quote from: zerozerosette on April 16, 2018, 09:12:58 amHello(I am not sure this the right section, sorry if it is not) I'm having problems with this cardhttps://www.amd.com/en-us/products/graphics/desktop/5000/5570My card is slightly different, as it hasn't the VGA connector (instead it has a displayport connector) so I'm using a dvi to vga converter. Installation of crt emudriver went fine - I followed the tutorial for newer cards - but when I try to enable EDID emulation my arcade monitor shows the windows desktop for less than a second, then the image starts to flicker (I think the signal switches back to 31khz). Could the dvi to vga converter be a problem? Any ideas?Thank you very much!There are 2 analog outputs configurable in VMMaker. Make sure to point to the right one for EDID emulation.
