Author Topic: invert y axis Autohotkey  (Read 3428 times)
Moksi
  • Last login:December 07, 2025, 10:21:53 am
« on: March 17, 2018, 04:16:36 am »
Is there someone that can help me out with an ahk to invert the Joystick Y Axis movement?
With Daphne if i play Astron belt the controls are inverted  DOwn = up, Up=Down with the Joystick.
Re: invert y axis Autohotkey
« Reply #1 on: March 17, 2018, 10:12:12 am »
Just create a second Daphne folder for that game and set the controls to what you need. I assume you’re launching Daphne from bat files so just aim the Astron one at that copy of Daphne. Easier than AHK.
Moksi
« Reply #2 on: March 17, 2018, 03:01:14 pm »
I read the Daphne control config it seems you cant invert the controls for the joystick it automatically picks up the settings.
« Reply #3 on: March 17, 2018, 03:40:40 pm »
I thought you could set it through the dapinput.ini. If it doesn’t exist you might need to create it
Moksi
« Reply #4 on: March 17, 2018, 05:46:25 pm »
yes i have the input.dll even set the keys in Daphne loader but Daphne automatically picks up the joystick and the y axis is inverted by default.
so i thought maybe try an ahk with invert but its probably complicated
