Author Topic: Black screen after flashing HD4350 with Atom15  (Read 3168 times)
Spardaradra
  • Last login:April 20, 2018, 09:32:37 am
« on: March 14, 2018, 06:05:21 am »
Hi guys, finally i was able to install CRTEmudriver on clean XP 64 install, but i wanted to take a try and flash my 4350 with atom15. I followed each step, saving bios, flashing bios (with AtiWinFlash), then i rebooted my computer...and voila, 15hz bios sequence, 15hz Windows logo....then, black screen.
I really dont understand why. Here's my setup
CPU : I3-3225
MB : Asrock B75 Pro3-M
4GB RAM
64Go Sandisk SSD
HD4350
J-Pac (set on 15hz only)
Everything plugged on my Egret 2
Any help.would be great, thank you
Calamity
  • Moderator
  • Last login:Today at 03:40:15 pm
  • Quote me with care
Re: Black screen after flashing HD4350 with Atom15
« Reply #1 on: March 14, 2018, 06:11:59 am »
Use the other output.
Steps to create a log:
Spardaradra
« Reply #2 on: March 14, 2018, 09:24:45 am »
Thank you, i'll try tonight after work
I'm plugged on the DVI output actually (with DVI--VGA adaptee), i will try VGA output tonight
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #3 on: March 15, 2018, 03:50:14 am »
yeah if you have native vga on the card, there's absolutely no reason to try using the DVI->VGA dongle
buttersoft
  • Last login:Today at 05:02:57 pm
  • Is running at 15kHz
« Reply #4 on: March 15, 2018, 04:36:54 am »
The ribboned VGA-ports, those not on the card PCB itself but connected by flat ribbon cable, are often subject to video noise. If you have a choice, the/a port on the PCB is better.
EDIT: card from the 6000 series and up obviously only have one analog output, so you don't always have a choice :)
« Last Edit: March 15, 2018, 07:05:13 am by buttersoft »
Spardaradra
« Reply #5 on: March 18, 2018, 07:07:58 am »
Many thanks to all of you and especially to Calamity for such a great work, now its working like a charm now on VGA output
