Author Topic: Recommended mapping for arcade cabinet controls to work with multiple emulators  (Read 1910 times)
juan9999
  • Last login:August 30, 2019, 12:07:37 pm
I've just installed retroarch and intend on installing as many classic emulators on my arcade cabinet as possible.
Is there a recommended setting or mapping for a two player arcade config (2 player, 2 rows of 3 button each, with 3 controls on each player (start, select, ...) that will work with the most emulators/games possible?
Something like:
X Y L1
B A R1
with controls start, select, quit (quit is not a player mapping but rather a retroarch control mapping to exit to front end)
What are your recommendations and why?
Drnick
  • Plodding Through Life
This one is a personal preference jobby,  I wanted to map them to be as close to original layout as possible so ended up with this setup for consoles. As soon as you throw shoulder buttons (Snes)  or 4 in a row (NeoGeo) requirements you have to make allowances.  I have a slightly curved layout so its a bit more forgiving.
Nes = BAStart BASelect
Sega MS = 121 121 (1 acts as start on MS)
Snes = LRY XBA OR LYX BAR
Genesis = XYZ ABC
NeoGeo = 123 444
juan9999
Do you use retroarch?  If so how do you pass it the config (specific for each emulator)
