Author Topic: Help with Optiwiz or UHID with a Chase HQ Wheel  (Read 4125 times)
asantora
  • Last login:August 08, 2021, 08:06:48 am
« on: January 31, 2018, 09:06:07 pm »
Picked up an optical wheel from a chase HQ. Would like to use it with a PC setup, but not sure if I should use an optiwiz or UHID. For those of you with experience, any help would be appreciated. Some questions that I have, with either setup:
Are additional buttons such as a shifter or pedal available as additional inputs on the optiwiz PCB?
Does anyone know this optical sensor is (pic below) and if it will work with Optiwiz or UHID?
I assume red is +5vdc and black is ground, does that sound right?
Thank you,
2huwman
  • Last login:August 16, 2025, 06:01:13 pm
Re: Help with Optiwiz or UHID with a Chase HQ Wheel
« Reply #1 on: February 05, 2018, 04:29:34 pm »
I'm afraid I can't help you too much with your specific questions, but I did use an optipac with a chase HQ cabinet and it worked well.
https://www.ultimarc.com/optipac1.html
Here's the little write up i did:
http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=65327&title=chase-hq-as-mame-driving-cab
asantora
« Reply #2 on: February 12, 2018, 07:21:00 am »
Thanks, will check it out. Also spoke to Andy and he confirmed that I could use the UHID. Will do a write up when finished
