Author Topic: Largest display on a battery powered Pi setup?  (Read 3198 times)
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« on: January 30, 2018, 03:53:15 pm »
I'm toying with the idea of starting a new project and currently just researching some of the constraints which will dictate design.
I'd like to known if there are any Pi based projects that have utilised a 9-12 inch display but have also been battery powered?
Any links/info greatly appreciated.
tikiandskull
  • Last login:April 10, 2019, 03:28:09 am
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
Re: Largest display on a battery powered Pi setup?
« Reply #2 on: January 31, 2018, 01:55:36 pm »
Depends on how long you want to play with it on one load.
A screen like that doesn't draw that much power (the 10 inch mentioned by tikiandskull uses a 5V 2A power supply - so at its max it will draw 2 Amps - my 7 inch can be powered through a laptop USB port even). With a 20.000mAh powerbank you should be fine for 3-4 hours at least.
If you need more power you could look into something like a LiPo, but that takes a bit more work (with battery protection and such).
GSXRMovistar
    • CoffeeCade
« Reply #3 on: January 31, 2018, 03:25:50 pm »
Thanks guys, so it seems it could be doable. Not too fussed about the time on battery as this is mainly for the fun in designing/building.
Going to attempt some rough design mockups to see what can be done around a 10" screen.
