Author Topic: Starting From Scratch  (Read 4364 times)
imtrashed
  • Last login:January 03, 2020, 02:47:10 pm
« on: November 16, 2017, 02:57:37 pm »
Be gentle.  Started reading up a lot recently, but hoping you can all save me some time.  Starting from scratch here.  What do I need at the bare minimum to get going with an arcade?  Not building any cabinet yet and not sure if I'll go with a full standup cabinet or something bartop.
Will likely just have the joystick/buttons on a piece of plywood to start.  Just want to start and see how this grows.
Will likely start with an old Windows XP laptop, unless I pick up a Raspberry Pi (if that's recommended).
Will use an old LCD TV to start.
Want to eventually pick up a trackball and a spinner, so I'd like to have that functionality as an option.
Looking to play classic 80s arcade games mostly.
If you were starting over with something bare bones that intends to grow, what would you buy?  What do I need?  And what's the most economical way to go about it?
2 joysticks, 6 buttons for them, 1/2 player coin and start, pause, volume
ipac?  ipac ultimate i/o?
Go ahead.  Start my addiction.
imtrashed
Re: Starting From Scratch
« Reply #1 on: November 16, 2017, 04:36:51 pm »
Or do I just buy an X-Arcade control setup to start and add that to a cabinet later on?
  • Last login:Yesterday at 11:47:06 am
« Reply #2 on: November 16, 2017, 04:38:39 pm »
Why not use an old CRT TV to start?  They are free or practically free. May as well start out right.
thomas_surles
  • Last login:June 19, 2023, 07:20:00 pm
« Reply #3 on: November 16, 2017, 04:45:40 pm »
I would start with building your own cp and not the x arcade. Better to learn by doing it.
  • Last login:Yesterday at 06:57:26 pm
« Reply #4 on: November 16, 2017, 05:15:06 pm »
The FAQ is a great place to start.
Since the wiki is still down, you can find a backup copy here.
https://web.archive.org/web/20160809113045/http://newwiki.arcadecontrols.com/index.php?title=FAQ
An XP laptop with a USB fightstick would be a great way to learn your way around the MAME and front end software, build your list of "gotta-have-it" games, try out different hardware like sticks/buttons, and practice your woodworking/finishing skills.
Based on your game preferences (some newer games need an XBox360 controller) and wanting to add a trackball+spinner, an I-Pac or Mini-Pac Opti is an excellent choice for the encoder.
-- I-Pac if you want to save a few bucks and practice fabricating wiring.
-- Mini-Pac if you want the convenience of a pre-fab wiring harness.
If you're looking for a lower-priced encoder, you can "roll-your-own" KADE miniArcade 2.0, but it won't handle the trackball/spinner inputs, so you'll also need an OptiWiz or StefanBurger's Illuminated Spinner firmware on an Arduino.
« Last Edit: November 16, 2017, 05:28:25 pm by PL1 »
imtrashed
« Reply #5 on: November 16, 2017, 07:29:18 pm »
I found a guy locally with an X-Arcade control panel, cabinet, and monitor.  Just need to hook a computer up to it.  The laptop I was planning on using is running super slow (and is an old Vista PC, which I hate too).  Always had some issues.  Am I better off picking up a Raspberry Pi for this?
thomas_surles
« Reply #6 on: November 16, 2017, 08:21:23 pm »
You can get cheap dell optiplexes on ebay for <$45
Id rather do that than a pi. Or an old pc off Craigslist.
imtrashed
« Reply #7 on: November 17, 2017, 09:15:25 am »
Going to try using the laptop or old PC I have at home.  Where do I go to begin to download the ROMs?  Now to also figure out which emulator(s) to use and figuring out the front end business.
  • Last login:Yesterday at 03:14:03 am
« Reply #8 on: November 17, 2017, 09:26:23 am »
Send a PM to PL1. He’ll hook you up.
« Reply #9 on: November 17, 2017, 09:28:26 am »
I see what you did there.
barrymossel
  • Spectrum
« Reply #10 on: November 17, 2017, 09:29:50 am »
ROMs: Google
Emulators & front-ends: lot's of reading here: http://forum.arcadecontrols.com/index.php/board,3.0.html
« Reply #11 on: November 17, 2017, 09:32:12 am »
See #5 here:police:
imtrashed
« Reply #12 on: November 17, 2017, 09:45:05 am »
See #5 here:police:
My post must have gotten cut off.  I meant "Where do I go to begin to download the ROMs for the original PCBs I own?"
« Reply #13 on: November 17, 2017, 09:46:59 am »
See #5 here:police:
Rule #5 still applies.
imtrashed
« Reply #14 on: November 17, 2017, 09:54:26 am »
My apologies about the ROM comments.  It was in jest.  Still obviously new to all of this, so just trying to get a feel for how everything works.  Been reading up a bunch, but there's a lot to digest and no real "How To" regarding software or getting started for a noob.  Very much appreciate the help so far.
Starting from scratch, what would you recommend I obtain to get my arcade going (based on my desire for predominantly classic arcade games)?  What software would I need to load onto either a PC or a Raspberry Pi (depending on which way I go)?  Is there a particular version of MAME?  A particular front-end software that's easy and intuitive?  I'll continue to read up, search, and look at stickys, but I'm going to pick up a cabinet with monitor and joystick / CP tomorrow, so I'd love to get going this weekend.  Thanks!
« Reply #15 on: November 17, 2017, 10:04:17 am »
No worries.
Keep reading and researching. You’re going to get a variety of opinions, so I’d look at previous builds to see what they’ve done, and go from here. I personally would use a PC, others would swear by the Pi.
jdbailey1206
« Reply #16 on: November 17, 2017, 11:18:30 am »
Others want to cut down the Pi, slice by slice...
jdbailey1206
« Reply #17 on: November 17, 2017, 11:19:55 am »
Make sure you research on what computers can run your emulators.  Otherwise you get yourself into a trick bag of not having enough computing power for the emulator.  ie A i3 wont run Dolphin...etc, etc.
imtrashed
« Reply #18 on: November 17, 2017, 12:18:56 pm »
Thanks.  Will do.  Basically just looking to run classic 80s arcade games (probably via MAME?) and also some Atari 2600 games and NES games.
barrymossel
  • Spectrum
« Reply #19 on: November 17, 2017, 01:50:25 pm »
No worries.
Yup, Pi is probably easier, but a PC has definitely more power and more options. I would say: beginner who want plug&play: pi, otherwise PC.
imtrashed
« Reply #20 on: November 17, 2017, 02:14:33 pm »
No worries.
I may go both routes to see how I like each.  And keep one on the new/used cabinet I'm getting and one for a new build.
If I want to get my PC started tonight, what do I have to download to get moving?  I'll download MAME, but what about a front-end?  Emu Loader?  Maximus?  MaLa?
imtrashed
« Reply #21 on: November 17, 2017, 02:18:12 pm »
And I may have an old PC without Windows on it also.  Might consider installing Linux on a new SSD hard drive.  Would that get me booted up more quickly?  No real experience with Linux, but I'm a quick computer learner.
paigeoliver
  • Last login:March 29, 2022, 06:10:15 pm
  • Awesome face!
« Reply #22 on: November 17, 2017, 03:21:31 pm »
Windows has better emulation software than Linux does. Boot times become meaningless once you have an SSD. My PC takes more time farting around in the Bios deciding if it wants to boot than it actually does loading windows. My XP Mame cabinet on 16 year old hardware also boots fast enough that it isn't even a real thing that I think about.
imtrashed
« Reply #23 on: November 17, 2017, 03:22:59 pm »
Thanks.  What do you use for frontiend software?
paigeoliver
  • Awesome face!
« Reply #24 on: November 17, 2017, 03:34:11 pm »
I cannot give any advice on any currently available frontend because I haven't tried a new one or updated one in at least 10 years. I used to use Mamewah. Your frontend is your last and least important choice, you could install all of them if you wanted.
« Reply #25 on: November 17, 2017, 11:13:18 pm »
If you're just looking to get started as easily as possible, you might consider one of the GUI MAME builds like MAMEUI, ARCADE (a continuation of MAMEUIFX), or MAMEUIFX. (0.175 or older)
The GUI builds aren't as configurable or pretty as a regular front end, but they are easier to get running.   ;D
imtrashed
« Reply #26 on: November 18, 2017, 12:17:32 am »
Thanks.  Might try one of those, as I've been getting really frustrated getting Gameex working.  Bailing on that and will be searching for another.
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #27 on: November 18, 2017, 12:32:27 am »
Some popular frontends...
Game Ex, Hyperspin, mGalaxy, Launchbox, Attract Mode... start with those.
And skip the X-Arcade controller. Its not that great.
imtrashed
« Reply #28 on: November 18, 2017, 07:39:54 am »
It's a cabinet with x-arcade controls and monitor for around $350 asking.  I thought it was a good deal to get started, even if I replace the controls soon enough.
