Author Topic: Invasion - The Abductors (MAME) Gun Reload issues  (Read 36863 times)
dgrace
  • Last login:August 19, 2025, 01:24:41 am
« on: November 04, 2017, 01:13:09 pm »
Hello,
I was playing this game and noticed how hard it is to reload.  If you're player 1 you have to shoot right in the right top corner (in a very specific spot) to reload and player 2 has to shoot in the bottom right corner to reload.  It's a little annoying.  I tried the cheat for infinite ammo and it didn't work:(.  Anyway, anyone have any ideas on how to fix that or make it easier to reload?  Thanks
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
Re: Invasion - The Abductors (MAME) Gun Reload issues
« Reply #1 on: November 04, 2017, 03:52:50 pm »
I actually submitted this to MAME testers a few days ago. Hopefully someone takes a look at it.
gstav
  • Last login:October 06, 2025, 02:10:15 pm
    • forum.arcadecontrols.com/index.php/topic,157861.0.html
« Reply #2 on: August 26, 2018, 06:21:40 pm »
BUMP
Any news on this?
"One coin to rule em' all"
  • Last login:Today at 02:29:02 am
« Reply #3 on: August 26, 2018, 11:23:48 pm »
Any news on this?
https://mametesters.org/view.php?id=6743
Status: Confirmed
Note by Hydreigon:
There are two reasons to this problem.
1. Gun mark isn't fully center the mark is slightly to the left of the cursor which doesn't make much sense to me because only up and left should be an offscreen reload in theory.
2. The fact Midway didn't include a gun calibration setting in the test menu isn't a good idea. It would be difficult to find a balance that is unless this game can use the quick offscreen reload setting that would involve remapping button 2.
gstav
« Reply #4 on: August 27, 2018, 03:42:22 pm »
Thanks mate :D Guess I have to remove this title then  :badmood:
Jollywest
  • Last login:Today at 02:20:51 am
« Reply #5 on: October 06, 2018, 04:48:57 am »
I use a bit of a work-around for easier reloading with Invasion. It's not perfect but makes it playable.
You need to set your controls up in the in-game TAB menu like shown in the 2 pics. Adjust the config to how your trigger and gun reload/button 2/off-screen reload is setup. For eg...
P1 Button 1 = Gun 1 Trigger or Gun 1 Reload
Lightgun X Analog Inc = Gun 1 Reload Button
P2 Button 1 = Gun 2 Trigger or Gun 2 Reload
Lightgun X 2 Analog Inc = Gun 2 Reload Button
Basically, the reload sweet-spot is all down the right hand side of the screen. When you press reload/shoot off screen the adjusted settings send the crosshair to the edge of the right hand side of the screen instantly. You then need to press reload/shoot off screen again to reload.
So to reload you need to press reload/shoot off screen twice.
gstav
« Reply #6 on: October 08, 2018, 03:28:12 pm »
Hehe cool find!  ;D Some sort of reaload anyways! Thanks! Now I can put it back in the database again as,, "working"  :cheers:
purbeast
  • Last login:October 03, 2025, 07:42:02 pm
« Reply #7 on: May 04, 2025, 08:40:24 pm »
I know this is an old thread, but I have been getting a light gun cab setup with MAME and trying to get this game right, and I think I have found what is a "better" solution via the MAME Input Macros where you can get actual one shot offscreen reloads.
First in MAME before loading any games, you have to enable the Input Macro plugin.
Once you do that, reload MAME and when you load up Invasion you can see the plugin folder in the MAME menu, and click that, and then go to Input Macro and create a new one.
I have a screen shot of my settings below:
And then here is a screen shot of my P1 controls, which are SLIGHTLY different than the other ones posted above.  The main (and only difference I think) is that P1 Button 1 is ONLY set to Joy 1 Button 0.
On my gun, Joy 1 Button 0 is on screen trigger pull, and Joy 1 Button 1 is off screen trigger pull.
So basically with the input macro, when you shoot offscreen, the game input settings move the cursor all the way to the right side of the screen.
Then the input macro is also activated, which waits 3 frames, to do a P1 Button input, which is what then shoots the edge of the screen and gives you the reload.
Here is a video of it in action - https://www.youtube.com/shorts/qtiiUPablrw
Now you will notice that like once or twice in that video, it appears I shoot off screen and it doesn't reload.  I am not sure but I have noticed it happening multiple times in that one part of the game where a lot of stuff is going on.  So I don't know if it could possibly be because of a frame drop or something.
I have also messed around with the "frame delay" option in the macro settings and when set to 2, it doesn't activate that often but sometimes will, and 3 seems to active like all the time.  I will say you can also FEEL that slight 3 frame delay of it happening since it's not instant like reloading in other games, however I think it is more natural and easier than having to do the double tap to reload, atleast for me it did when I was in a hectic part of the game.
I also had this working with the auto-fire plugin, but with that you had to hold the trigger down ever so slightly when pulling the trigger off screen, and it also felt just not as natural as the single click we're all used to.
« Last Edit: May 04, 2025, 08:42:36 pm by purbeast »
Endprodukt
  • Last login:October 17, 2025, 10:59:15 am
« Reply #8 on: June 01, 2025, 12:46:47 pm »
I tried your method. Cool find, not 100% reliable but better than the double shot thing. Thank you!
purbeast
« Reply #9 on: June 02, 2025, 11:44:39 am »
Did you try the autofire way too?  I haven't really gotten around to playing the game more than just testing these out but once I get my cabinet all finished up I will try the full game and see how it goes.
Endprodukt
« Reply #10 on: June 03, 2025, 12:48:02 am »
I have not heard of that method, can you elaborate?
