February 20, 2026, 01:29:55 pm
Just an update,If I try to EDID emulation I get no picture at all. (I presume the ranges are too high) my tv is an Toshiba 36zp18. Thanks
Sounds like a sync. signals issue. Check if you can use the UMSA from "CRT 1" on the Toshiba TV set to confirm. Normally, a 100-Hz set will display ~60-Hz modes, but it's not the best set for that purpose due to the process involved.
Picture now stable at pal 50hz settings but have a black bar across the middle...... Hmm it definitely prefers 50hz
The cable is fine, it cost fme £60 8 years ago. It doesn't make sense
Quote from: cornhairboy on September 15, 2017, 04:23:38 pmThe cable is fine, it cost fme £60 8 years ago. It doesn't make senseYou're missing vertical sync.Your cable doesn't combine hsync and vsync into composite sync (c-sync)Either:- Get another cable.- "Mod" your cable.- Install CCC and try to enable c-sync using it (good luck)
Does it look like the v and h sync have been put together?
