Author Topic: Second crt has picture jumping with crt emu driver via vga to scart lead  (Read 5678 times)
cornhairboy
  • Last login:September 21, 2017, 01:05:29 am
Hi all
Need some help. Ok I'm running a ultimate scart adapter that works amazing with crt 1. My second crt is using a vga to scart cable (which I had working many years ago via sci tech display doctor settings) but using calamity amazing vga driver I either get no picture or it jumps everywhere.
Please please any support would be great!!!!
« Last Edit: September 15, 2017, 08:56:45 am by cornhairboy »
cornhairboy
Re: Second crt has picture jumping with crt emu driver via vga to scart lead
« Reply #1 on: September 15, 2017, 07:36:18 am »
Just an update,
If I try to EDID emulation I get no picture at all. (I presume the ranges are too high) my tv is an Toshiba 36zp18. Thanks
cornhairboy
« Reply #2 on: September 15, 2017, 01:41:43 pm »
Just an update,
OK so I've managed to slow the vertical scrolling by forcing the modelines towards 50hz but the lowest I can get is 52hz. Now, this tv is a 100hz scan rate, can I get it running at that instead?
Recapnation
    • Eiusdemmodi
« Reply #3 on: September 15, 2017, 03:51:39 pm »
Sounds like a sync. signals issue. Check if you can use the UMSA from "CRT 1" on the Toshiba TV set to confirm. Normally, a 100-Hz set will display ~60-Hz modes, but it's not the best set for that purpose due to the process involved.
cornhairboy
« Reply #4 on: September 15, 2017, 04:10:43 pm »
Yep, the ultimate scart adapter works fine on the Toshiba. Tried this a couple of days ago, how can I get round this problem. I really don't want to have to buy a second Ultimate scart adapter,  I really hoped my specialist vga cable would work again....
Any suggestions next
Recapnation
    • Eiusdemmodi
« Reply #5 on: September 15, 2017, 04:18:28 pm »
You'll need to fix the cable, then?
cornhairboy
« Reply #6 on: September 15, 2017, 04:23:38 pm »
The cable is fine, it cost me £60 8 years ago. It doesn't make sense
cornhairboy
« Reply #7 on: September 15, 2017, 05:41:44 pm »
Picture now stable at pal 50hz settings but have a black bar across the middle...... Hmm it definitely prefers 50hz
« Last Edit: September 15, 2017, 05:43:44 pm by cornhairboy »
cornhairboy
« Reply #8 on: September 15, 2017, 05:56:25 pm »
Even stranger is when I try a different interlaced resolution the black bar moves. It almost as if the v sync can't lock.
I think I'm going to give up now, get a vga to component converter and run via component,
Doesn't matter too much I still have my main crt on my machine
  • Last login:February 17, 2026, 02:43:50 am
« Reply #9 on: September 15, 2017, 05:58:26 pm »
The cable is fine, it cost fme £60 8 years ago. It doesn't make sense
You're missing vertical sync.
Your cable doesn't combine hsync and vsync into composite sync (c-sync)
Either:
- Get another cable.
- "Mod" your cable.
- Install CCC and try to enable c-sync using it (good luck)
cornhairboy
« Reply #10 on: September 16, 2017, 02:58:01 am »
Either:
- "Mod" your cable.
OK that makes sense I remember some setting in sci tech display doctor that did this.
OK so next question which is the best cable to get and where from
How easy is it to mod and is there any tutorials?
Thanks again
cornhairboy
« Reply #11 on: September 16, 2017, 04:09:45 am »
Ok so here is the scart I have taken pictures of....
Does it look like the v and h sync have been put together?
« Last Edit: September 16, 2017, 04:15:38 am by cornhairboy »
« Reply #12 on: September 16, 2017, 04:55:32 am »
No. I'd say the yellow cable is h-sync. You should see two cables going to pin 20, check this: http://www.geocities.ws/podernixie/htpc/cables-en.html
That's the most simple schematic. Other schematics use a few other components to provide a better quality c-sync.
cornhairboy
« Reply #13 on: September 16, 2017, 05:09:16 pm »
Thanks calamity,
I've decided to bite the bullet and purchase a ready made scart with vsync all completed from retr80s on eBay.
I will get you the results as soon as I receive it!
