Author Topic: Has anyone used Blum CLIP hinges?  (Read 990 times)
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« on: January 29, 2004, 04:12:16 pm »
As stuff is arriving in the mail I think I have decided to switch from a UA1 based design to LuSiDs.  One thing I definately wanted was the option of a removable CP (and I liked the hinged CP a lot of people use around here - seems like it would be easy to work on etc).
While looking around for options I found these CLIP hinges.  They are concealed cabinet hinges that clip onto the mounting plate (which are available separately).
Their site is at:
http://www.blum.us/webv2.nsf/html/US_02_01!OpenDocument
It looks like they just have a spring loaded latch for releasing it so they might be ideal.
Has anyone used these before?  Is there something I'm missing?
« Last Edit: January 29, 2004, 04:13:05 pm by Zathras »
Space Warped by Someone
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:Has anyone used Blum CLIP hinges?
« Reply #1 on: January 29, 2004, 04:57:03 pm »
I'm using similar Salice hinges for cabinet's front door:
For the control panel, though, I just used a piano hinge
because I wanted it to lift up on the side, and the top of the control panel sticks out beyond the box a bit.
Zathras
  • Yeah.
« Reply #2 on: January 29, 2004, 05:26:01 pm »
I didn't even think about using them for the front panel door - thats a good idea and could come in handy.  Are they easy to remove?
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #3 on: January 29, 2004, 07:18:09 pm »
I have hinges like this on my kitchen cabinets and they work great there.  I'm sure they'd work just fine in a cabinet as well (after all it is a "cabinet" too).
_Iz-
  • Last login:Yesterday at 05:10:59 pm
  • Time to coin up!
« Reply #4 on: January 29, 2004, 07:29:20 pm »
They'd work OK, you need a fair bit of depth inside your box for the arm and some extra room to get your finger behind the arm to unclip the hinge from the plate (maybe 3 1/2" total bare minimum). They generally only open 107
Zathras
  • Yeah.
« Reply #5 on: January 29, 2004, 10:47:52 pm »
