Author Topic: emu4crt Mednafen mod - update 1.26.1  (Read 113974 times)
silmalik
  • Last login:April 16, 2022, 09:08:13 am
    • Mednafen emu4crt mod
Re: emu4crt Mednafen fork - updated to 0.9.48
« Reply #40 on: November 11, 2017, 01:12:42 pm »
Yes, here it is  :cheers:
Ok, it seems that emu4crt is doing his job: switching to 256x288.
So, your problem should be related to your PAL modelines. You can check them, one by one, with Arcade_OSD.  ;)
alex2005
  • Last login:December 20, 2023, 09:21:14 am
« Reply #41 on: November 11, 2017, 03:01:49 pm »
Thanks for the hints! I will check them, first i need to look how to use arcade_osd because i never used it before :)
In the meantime switched some of the roms to the respective ntsc version, and they seem to work fine. I did also some tests to convert pal to ntsc roms and this seems to work well so far :)
I will check the remaining roms that have no ntsc version and try to fix them with arcade_osd.
Again thanks and keep the good work!! Its awesome what you do with emu4crt :) :) :)
Dacasks
  • Last login:February 09, 2021, 09:30:30 pm
« Reply #42 on: November 17, 2017, 11:29:06 am »
Well, I'm pretty sure that vsync will prevent any tearing. ;)
About input lag, emu4crt should not be worse than the official build, and, just in case, the Mednafen Team gives some recommendations: https://mednafen.github.io/documentation/#Section_lag
Blit time Sync was activated, that was causing more input lag, sorry. Now it's fine like the vanilla build, but what I meant about no screen tearing is the same solution as Groovymame: No tearing without needing the "regular vsync" which introduces lag.
I guess that isn't possible for now. But it's great already... just need to ignore the tearing.
Lindiu
  • Last login:August 23, 2022, 09:10:09 pm
« Reply #43 on: January 04, 2018, 04:36:35 pm »
Hi, the PSX bios transition is fixed?, I have an error starting a lot of PSX games ( with no problems in others).
Error:
Assertion failed!: ... video.cpp, Line 1218
Expression: dest_rect.h > 0
silmalik
« Reply #44 on: January 04, 2018, 05:51:39 pm »
Hi,
I didn't know about such error, so... there is no fix for now.  :)
Please, could you give one or more game which produce the error ?
Log file may help too.
Thank you.
Lindiu
« Reply #45 on: January 04, 2018, 06:46:57 pm »
The X-Files, for example. Tomorrow I'll upload the log file.
silmalik
« Reply #46 on: January 05, 2018, 03:22:34 am »
It's ok, I can reproduce on several games.  :o
I will work on it.
Lindiu
« Reply #47 on: January 05, 2018, 10:27:32 am »
Thank you :applaud:
silmalik
« Reply #48 on: January 06, 2018, 10:00:12 pm »
Error:
New release! It should be fixed.  :)
Is it possible to build a Windows 32bit version?
A 32bit version is available... in case you didn't migrate to a 64bits OS until today.  ;)
retrorepair
  • Last login:April 14, 2023, 04:49:58 pm
Re: emu4crt Mednafen fork - update 0.9.48 / A06
« Reply #49 on: January 17, 2018, 02:55:58 pm »
Fantastic! This is now the number one way to play PS1 on a CRT with a PC!  :applaud:
Thank you so much for your work silmalik!
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
alex2005
« Reply #50 on: January 18, 2018, 04:22:45 am »
Would it be possible to display the control remapping a bit upper on the screen? when I use it on the arcade monitor it always displays at the bottom of the screen (usually i stretch it to match most of the games resolutions), for which i have no visibility.
It doesnt have to be in the center, as long as it is a few lines  upper and not at the bottom should be fine - maybe something like MAME style  :)
I can always stretch the monitor display, adjust the controls and then stretch it back, so its not a big deal, but just a small feature request :)
« Last Edit: January 18, 2018, 04:24:19 am by alex2005 »
silmalik
« Reply #51 on: January 18, 2018, 10:04:09 am »
Thank you, I'm glad you apreciate.  :)
Could you confirm that you use the last version ?
OSD messages are already displayed a bit upper to prevent overscan, but maybe it's not enough in some situation.
I like comfort too, so I will have a look on this if I can reproduce.  ;)
alex2005
« Reply #52 on: January 18, 2018, 12:47:29 pm »
my bad, I thought I was using the last version, but I was not.
The latter one is perfect! Fonts display bigger and no longer out of my screen range.
Thanks a lot!!
silmalik
Re: emu4crt Mednafen fork - update 0.9.48 / A07
« Reply #53 on: January 18, 2018, 07:42:42 pm »
A07 Update: support of Super Resolutions added.
Configuration file update is required since resolution switch is now defined with "video.resolution_switch" parameter.
Accepted values are: 0 (default), native and super.
Feel free to report any issue or suggestion.
alex2005
« Reply #54 on: January 19, 2018, 08:00:28 am »
Just tried the latest version, its such an awesome job what you are doing!
So far works great with native resolutions, but I must say Saturn using super resolutions looks even better :)
Thanks a lot for all your time and dedication! :)
hotdog963al
  • Last login:July 07, 2018, 06:03:45 am
  • PVM-14M2E
« Reply #55 on: January 23, 2018, 06:38:18 pm »
Hey, thanks so much for this.
I started fiddling with the A05 release a few weeks back, but quickly noticed the frequent horizontal switching on PSX was not great for my PVM, so I hacked about with the GPU code and got it outputting at 2560 wide which worked perfectly. I see you've included this feature in the newer version which is great.
Another issue I had however was with how Mednafen itself handles positioning/overscan, for example, at certain horizontal resolutions, you either end up with stuff being incorrectly cropped, or extra black bands being added (note how screenshots are never the right res). I eventually managed to get the code working so that the output was exactly perfect with no black bands or incorrect cropping, save for a slight crop at the 368 res which wound up at 365 (due to it being @ 2560).
Would you be interested in fixing this issue in your version? I can supply some diffs if you'd like to see what I did to get it working.
Cheers
silmalik
« Reply #56 on: January 24, 2018, 02:42:33 pm »
Hi hotdog963al,
Yes, of course, I'm eager to test your fix!  :)
Please, send your diffs and I'll try to integrate them in my mod.
hotdog963al
  • PVM-14M2E
« Reply #57 on: January 24, 2018, 05:01:23 pm »
Hi hotdog963al,
Here's the entire gpu.cpp file. I isolated the changes that were relevant and integrated them into the code from your A07 release. Seems to work!
https://pastebin.com/raw/KyQ8jXPa
Here's a few screenshots as well to just give you an idea, I've tested all resolutions and it works great. Granted, 3px are lost at 368, but that would take quite a bit more effort to resolve and I honestly don't think it's worth it. :laugh:
https://imgur.com/a/gp1MZ
silmalik
« Reply #58 on: January 24, 2018, 07:58:45 pm »
Ooooh it works great, well done!  :)
It seems to fix Mednafen's global PSX horizontal centering issue, maybe you should contact the team to expose what you've done.
If you are ok, i will integrate your fix "as is" in a next release.
Thank you for sharing.
retrorepair
« Reply #59 on: January 25, 2018, 01:01:20 pm »
I don't suppose I could ask a strange favour?
I'm working on getting the original NES Zapper working which I'm confident it should, I just need the optical sense line exposed as an input, would that be possible? I don't know where to start compiling mednafen or I'd do it myself!
silmalik
« Reply #60 on: January 25, 2018, 03:00:49 pm »
Hi retrorepair,
Well, I don't understand your request, sorry.  Don't know what is the optical sense line ?  ???
I'm not very experienced with cpp, so, if you feel confident to make your mod by yourself, I can help to get a compilation environment.
retrorepair
« Reply #61 on: January 25, 2018, 04:14:14 pm »
That would be very helpful, thanks! I'll PM you after work
hotdog963al
  • PVM-14M2E
« Reply #62 on: January 27, 2018, 08:56:55 am »
Great! Glad to hear it's working for you.
By all means go ahead and include it, it'll save me having to patch it in every time you release an update! :D
0mike0b
  • Last login:December 23, 2021, 01:34:40 pm
« Reply #63 on: February 10, 2018, 04:46:25 pm »
Hello! I'm very interested in using Emu4CRT in super resolution mode but I can't seem to figure out what I'm doing wrong when I try to set the option in mednafen-09x.cfg
Is there any way somebody could go in to detail on how to set super resolution mode in the cfg or maybe send a working cfg file. It would be a huge help thanks so much to anyone reading this!
alex2005
« Reply #64 on: February 10, 2018, 06:31:34 pm »
i went through the documentation and its quite straight forward,  did you install the required modelines in vmmaker?
0mike0b
« Reply #65 on: February 11, 2018, 08:25:33 pm »
Yes I have all 4 of them required for Super Resolutions. If it is so straight forward maybe you can help me find where I am messing it up. I attempt to add an option at the end of my config for mednafen like so
video.resolution_switch Super
It always gets moved to a section of the cfg titled "Unrecognized Settings Follow:"
silmalik
« Reply #66 on: February 12, 2018, 08:23:51 am »
Hi,
Once launched, emu4crt should add required lines in cfg file by himself, and not in "Unrecognized" section of course:
;Video resolution switch (0, native or super).
video.resolution_switch 0
If you still have troubles, please check that you are using the correct executable version and post cfg & stdout file. Thanks.
terranigma
  • Last login:March 20, 2019, 04:03:17 am
« Reply #67 on: February 18, 2018, 02:41:46 am »
Hi silmalik, thank you for your effort.
Is this mod Windows specific or other systems (say, Linux) that mednafen supports can benefit of it?
silmalik
« Reply #68 on: February 18, 2018, 12:18:26 pm »
Hi terranigma,
No specific Windows code has been added, just some calls for SDL standart functions, so... it could work on other systems. :)
terranigma
« Reply #69 on: February 20, 2018, 09:07:30 pm »
I just made a quick test on Linux with psx and snes and it behaves very well! One thing I noticed is that snes runs in a narrowed picture then I checked actual resolutions. Well, I see that It runs on "384x288" resolution instead of "256x288" which emu4crt claims.
"video.resolution_switch" is "native".
### VIDEO Native resolution init - set to 256x288
  Video Driver: OpenGL
  Video Mode: 256 x 288 x 32 bpp
  Shader: none
  Fullscreen: Yes
  Special Scaler: None
  Scanlines: Off
  Destination Rectangle: X=0, Y=0, W=256, H=288
  OpenGL Implementation: nouveau NVA5 3.0 Mesa 17.2.4
  Checking extensions:
   GL_ARB_texture_non_power_of_two found.
   GL_ARB_sync found.
  Using non-power-of-2 sized textures.
  Checking maximum texture size...
   Apparently it is at least: 8192 x 8192
  Using GL_BGRA, GL_UNSIGNED_INT_8_8_8_8_REV for texture source data.
MAIN - native resolution switched
$ xvidtune -show
"384x288"       7.41    384  392  427  472    288  291  294  314 -hsync -vsync
EDIT: Similar issue also appears on psx's intro and demo stages but actual game runs on claimed resolution.
« Last Edit: February 20, 2018, 10:19:40 pm by terranigma »
silmalik
« Reply #70 on: February 21, 2018, 01:39:48 pm »
Hi,
Well, unexpected behaviour indeed.
It seems to act like some video mode are unavailable on your system or emu4crt does not correctly set initial video mode.
- Is the window correctly sized in window mode ?
- If you disable native/super resolution and manually set 256x288 in fullscreen, does it work ?
Could you try Snes games that change resolution (ex: Secret of mana, blues brothers), let them swith and post complete log file ?
Thank you.
terranigma
« Reply #71 on: February 23, 2018, 01:39:04 pm »
Hi,
Thank you.
You're right. It's my bad. I thought that emu4crt is going to tune required modelines like groovymame. When I add some modelines for testing, emu4crt uses the closest one to switch if required one is not available.
silmalik
« Reply #72 on: February 24, 2018, 12:11:25 pm »
Ok, good news.
Thank you for the feedback.
Foxhole
  • Last login:April 11, 2024, 04:05:15 am
« Reply #73 on: February 25, 2018, 12:56:21 am »
Is there a way to use hard sync with mednafen, like with retroarch? It really helps reducing input lag.
silmalik
« Reply #74 on: February 25, 2018, 10:04:03 am »
I don't know about this.  ???
Recent Mednafen release is based on SDL 2, maybe it opens way for such improvement.
You may ask directly the Mednafen team for such feature. :)
terranigma
« Reply #75 on: March 04, 2018, 11:26:40 am »
Hi silmalik,
Any plan on Mednafen 1.21 ?
silmalik
« Reply #76 on: March 04, 2018, 06:20:11 pm »
Hi terranigma,
Yes of course, work in progress... should be available this week.
silmalik
« Reply #77 on: March 05, 2018, 06:08:55 pm »
Hi silmalik,
Done! :)
buttersoft
  • Last login:May 13, 2024, 07:03:28 am
  • Is running at 15kHz
« Reply #78 on: March 07, 2018, 05:32:40 pm »
If mednafen or emu4crt switches to a 31kHz mode, you can try this fix:
  1 - Stop and Disable service: AMD External events utility
  2 - Ensure that the Windows advanced display option is enable: "hide modes that is monitor cannot display"
This service often resets the "hide modes", so standard 31kHz video modes are exposed to applications, not good for our usage.
A bit late, but thank you for this post. And to Calamity for highlighting it. I was having an issue where a frontend i'd setup on an LCD was grabbing a 31kHz mode out of nowhere - it had never used that resolution before. Stopping and disabling the AMD External Events Utility fixed it.
As a side note, the second step does not seem to be needed for Win10. In fact I can't even find if that option still exists or is built-in now.
silmalik
Re: emu4crt Mednafen fork - update 1.21.0 / A08
« Reply #79 on: March 08, 2018, 04:21:25 pm »
Hi buttersoft,
Thank you for the feedback, I'm glad that you have fixed your issue.
The setting can still be found in Windows 10: Display settings / Display adapter properties.
