Author Topic: Mamehooker + I-Pac Ultimate I/O issues  (Read 11705 times)
Sky25es
  • Last login:November 24, 2025, 12:35:19 pm
« on: August 08, 2017, 10:42:24 pm »
Does someone know if the I-Pac Ultimate from Ultimarc works with Mamehooker ? I tried to light up some leds but the App tells me that there is no Ultimarc Device.
It's strange cause it works without issues with Ledblinky
Update:
The problem is resolved in the next version of Mamehooker, thanks to Howard Casto (...and his patience  ;)). Thanks also to Andy from Ultimarc for his assistance.
« Last Edit: August 21, 2017, 06:38:27 pm by Sky25es »
Headrush69
  • Last login:October 26, 2025, 05:02:32 pm
  • I have build my own arcade controls!
Re: Mamehooker + I-Pac Ultimate I/O issues
« Reply #1 on: August 31, 2022, 06:07:14 am »
Update:
What version was this fixed in?
I have the same issue using Mamehooker 5.1
Moleburt
  • Last login:July 24, 2023, 05:40:31 pm
« Reply #2 on: September 29, 2022, 11:28:40 am »
Update:
Did you ever get your issue resolved @Headrush69?
Headrush69
« Reply #3 on: October 08, 2022, 04:59:43 pm »
No. I cannot get MameHooker to see my iPac Ultimate. (USB ID:D209:0410)
Edit: Thanks Moleburt. With that updated MameHooker it is working.
« Last Edit: October 16, 2022, 02:06:24 pm by Headrush69 »
Jaybomb999
  • Last login:October 18, 2025, 09:45:07 pm
« Reply #4 on: December 03, 2022, 05:32:13 pm »
Hello @Headrush69 and @Moleburt.  My I-Pac Ultimate is also not being detected by Mamehooker 5.1.  Do either of you have a link to the version that fixes this issue?  I cannot find anything...
Edit:  Thank you Headrush69!  The modified mamehooker.exe and PacDrive32.dll solved the problem for me.
Edit 2:  You can download the modified mamehooker and PadDrve32.dll at the link below:
https://drive.google.com/file/d/1msniDRIiyyAuPufYWKWMsmoxjfyRMH_y/view?usp=drive_link
« Last Edit: August 21, 2023, 07:59:22 pm by Jaybomb999 »
scoodidabop
  • Last login:December 01, 2025, 11:25:31 am
« Reply #5 on: May 12, 2023, 04:37:14 pm »
Same issue here - any idea where I can pickup the modified mh exe and correct PacDrive for the ultimate board?
PolybiusExtreme
  • Last login:June 08, 2024, 01:12:10 pm
« Reply #6 on: May 26, 2023, 05:18:35 am »
hi @headrush69
i have the same issues with my ultimate io boards... can you share the modified mamehooker.exe, please?
Vitaly17
  • Last login:November 20, 2025, 03:37:50 am
« Reply #7 on: July 11, 2023, 03:44:30 pm »
Hello. I have the same problem. I have two I-pac Ultimate. I tried to light up some leds, but mamehooker tells me that there is no Ultimarc device. It works fine with Ledblinky.
Could you please help me with a modified mamehooker exe?
Thanks to Jaybomb999. With modified mamehooker.exe and PacDrive32.dll all works great.
« Last Edit: July 13, 2023, 04:07:41 am by Vitaly17 »
Kierdo
  • Last login:October 27, 2023, 01:40:42 am
« Reply #8 on: August 20, 2023, 01:01:50 pm »
I have the same issue... no Ultimarc IPAC Ultimate board is detected. Where can I grab the compatible exe? I cpuld not find it anywhere and Ledblinky is working ok.
Thanks!!!
« Last Edit: August 21, 2023, 04:42:55 am by Kierdo »
Jaybomb999
« Reply #9 on: August 21, 2023, 08:00:38 pm »
Hello Kierdo,
I have added a link to my last post.
Kierdo
« Reply #10 on: August 22, 2023, 05:12:38 am »
Hello Kierdo,
Thanks! I sent you a request to download the file :)
It is not a public link, so I need your autorisation to download.
You're great!!
« Last Edit: August 22, 2023, 04:14:04 pm by Kierdo »
Vitaly17
« Reply #11 on: August 29, 2023, 11:24:49 am »
Mamehooker works, but there are some problems. I have two ipad ultimate boards and a servo stick control board from ultimarc. Due to servostick, the second ipad board works as board3 and not board2. When you click on the Show supported device in mamehooker, the boards are not located, but they work in the test menu and games. The saddest thing is, after exiting mamehooker, the dll error error 6 appears and after the program sometimes does not work correctly. Has anyone faced such problems?
Kierdo
« Reply #12 on: September 01, 2023, 07:00:14 pm »
Mine is not working. I downloaded the last version from creator's web and no luck.
It does not show compatible devices and also is not working in test menu (tested every ID). Could you send me the modified version?
Many thanks in advance!
teeboz
  • Last login:April 03, 2024, 01:36:40 am
« Reply #13 on: September 28, 2023, 01:56:50 am »
i am in search of the modified version also.  Can someone send me a link?
thanks
« Last Edit: October 01, 2023, 10:42:24 pm by teeboz »
tjeerd159
  • Last login:February 05, 2025, 03:06:08 pm
« Reply #14 on: October 30, 2023, 10:43:59 am »
I am looking for the modified version as well. Can someone share it?
scoodidabop
« Reply #15 on: December 28, 2023, 02:08:53 pm »
thanks
Link: https://www.mediafire.com/file/k5et3j5yn2ebd7h/mamehooker5.1_ultimateIO.rar/file
scoodidabop
« Reply #16 on: December 28, 2023, 02:10:27 pm »
OMG you just saved me loads of headache, trying to figure out why my 2nd board was only working when plugged in by itself. At any rate it's still really annoying that the servo stik bumps the 2nd board to board3, it really screws with my settings :/
desert_dweller_88
  • Last login:February 12, 2024, 08:06:30 pm
« Reply #17 on: January 01, 2024, 09:16:20 pm »
Omg thank you for this!!!! I made a different post about this and couldn't get help any where
desert_dweller_88
« Reply #18 on: January 02, 2024, 01:18:37 am »
Update:
Well spoke too soon, idk what the hell I'm doing wrong. I downloaded the io version from above but beyond not seeing any devices I still cannot test any of the boards I tried devices 1 to 4. Is there a specific directory location this needs to be placed? Do the boards need to be in xinput mode? Any help is appreciated because I'm struggling here
Fursphere
  • Last login:November 17, 2025, 08:30:46 am
« Reply #19 on: February 12, 2024, 11:23:28 am »
Just starting to play with Mamehooker.  It does not see the Ultimate IPac in either of my cabinets as well.  :(
uptown47
  • Last login:December 01, 2025, 09:34:57 am
  • Just takin' life one game of Frogger at a time...
« Reply #20 on: August 25, 2024, 10:26:01 am »
Has anyone managed to get this working? I'm having the same issues? I've tried the Mame Hooker in the MediaFire link a few posts up but it's still the same.
I have an Ultimate I/O and a LED64 on the same cab. The LED64 works fine (although it's controller 1 in MH and controller 2 in LEDBlinky) but the Ultimate I/O doesn't see to be detected?
Any help or a link to another MH version to try would be very much appreciated. :-)
Vitaly17
« Reply #21 on: August 29, 2024, 06:07:10 am »
Hi. Here is a link to a working ipac ultimate
mamеhooker that works for me.
https://www.mediafire.com/file/21omrzrlk3m4mpo/mamehooker.7z/file
Now I will tell you some unpleasant features of this version, and maybe not only this one. Sorry for my English) I have two ipac ultimate boards, as well as one servo stick control board from ultimarc. If I knew that this would bring me so much headache, I would have just bought several pacled64 boards.
1) The boards will still not be displayed when you click show supported devices, but they will work in test mode.
2) If you accidentally enter a non-existent board number in the commands (in my case, it is servo stick control board) and some error occurs, the program may not work until the next PC boot.
3) the program may also simply not work after the PC boot. I completely solved this problem by connecting the boards after booting the computer using a controlled USB hub and the ulk 2 and ulk 3 commands.
4) The LEDs will work in MAME, but after exiting and closing mamehooker, a DLL error 6 occurs and the program will stop working until the next PC reboot. There will be no error only if you run the game directly through MAME. If you use the command line or frontend, then there will be an error. Therefore, I do not use them in MAME, only when using Demulshooter (And you need the latest versions of demulshooter, otherwise after exiting, there will be a dll 6 error)
5) If you suddenly use Ledblinky, disable all outputs and delete mame.dll, otherwise nothing will work normally.
6) It is better to run both the emulator and mamehooker as administrator.
I would also like to add. If you have the opportunity and want to use mamehooker, buy other boards. I would gladly change them myself, but there is no possibility of delivery to my country(((
uptown47
« Reply #22 on: August 29, 2024, 06:43:52 am »
Thank you for the link and the benefit of your advice.
I get the impression there has been a LOT of trial and error in managing to compile all that knowledge!
I will have a think on the best way to approach this but, based on some of the problems you've described, I may just stick with LEDBlinky.
Many thanks for posting this info and all your help. :)
