Author Topic: MS Pac-man bootleg, graphics problems  (Read 2087 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: May 21, 2017, 12:37:01 pm »
Hi all
I just got a MS Pac-man bootleg PCB. It has some slight graphics problems on the main screen, and
upon maze attract mode the ghosts and the player are just colored blocks. I have tried reseating the
eight EPROMS on the board. Any advice would be great :)
https://www.youtube.com/watch?v=FZhdlkCI4iY&feature=youtu.be
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Re: MS Pac-man bootleg, graphics problems
« Reply #1 on: May 21, 2017, 02:16:35 pm »
Bad 5E? Make sure all legs are clean and none are folded over.
ed12
« Reply #2 on: May 21, 2017, 02:19:22 pm »
look for the video rams
what u are seeing is called sprites
it comes from a bad seated ram/eprom
ed
AE35
« Reply #3 on: May 21, 2017, 03:24:34 pm »
Thanks! How do I know which eprom are equal to 5E? or the others, for that matter. I have attached a picture of my Falcon bootleg below.
The row closest to the edge connector are 2732's the row behind is 2716's. If I burn new eproms, what should I use - and where should they
go?
It seems that only the eproms are in socket. I can't even find the ram on the picture  :banghead:
ed12
« Reply #4 on: May 21, 2017, 03:46:45 pm »
it is labled 9
look at the side of your board
it is printed 1-9
go to 5 this is your row
e=5th chip over
as from the bottom of the row counting up it is a 74ls style
come in the other way
wala a eprom marked 9
your rams are on row 0 and 1 or 1 and 2
ede
AE35
« Reply #5 on: May 22, 2017, 08:41:47 am »
Thanks! I wasn't sure that the bootleg used the same placement of the eproms.
Eprom 9 is a 2716, which can hold 2kb. The 5E data (obtained from a mame-set of pac-man) is 4kb.
Which makes be doubt if this bootleg is using the exact same roms as an original board? I just want to
burn a new eprom and see if it works :)
Thanks for your time!
