Author Topic: Spinner AND PC wheel  (Read 4043 times)
raph
  • Last login:May 25, 2024, 03:21:37 am
  • Gradually adding bells and whistles to a stock cab
« on: May 17, 2017, 09:44:35 pm »
I've already got two spinners in my cab  for stuff like two player Warlords. I also have a working PC wheel (an old Logitech) that can handle 270 degree games and has pedals.
This may be a silly question, but... What is the correct way to get these configured in MAME so they can co-exist? Set spinner games to use Dial and 270 games to use Paddle?
  • Last login:Today at 04:25:05 am
Re: Spinner AND PC wheel
« Reply #1 on: May 17, 2017, 10:29:08 pm »
The spinners show up as mouse X-axis and Y-axis.
The wheel shows up as a gamepad analog axis.
If MAME sees both mouse and analog control inputs, games like Warlords will accept input from both by default.
Go into the "Input (this Game)" menu and re-map the input(s) to whichever control you want to use in that game and they won't interfere with each other.   ;D
While you are dong that, be sure to set the "INC" and "DEC" inputs to "None". (Enter then ESC)
« Last Edit: May 17, 2017, 10:35:02 pm by PL1 »
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #2 on: May 18, 2017, 06:39:46 pm »
Be aware that on just about every 360 degree wheel game you will have to adjust the sensitivity.  There's really no way to do this without going into each game and making the adjustment.
raph
« Reply #3 on: May 18, 2017, 06:49:15 pm »
Yeah, been running into that already. I am using a table of tooth count and counts per rev which I got from archive.org's version of the wiki, but it has a lot of holes. If there's a better repo of that info, I'd love a pointer to it.
processedmeat
  • Last login:December 18, 2025, 05:50:22 pm
  • Ikeakade Here I come!
« Reply #4 on: June 04, 2017, 08:01:39 pm »
Do you have a link to that particular page?
adder
« Reply #5 on: June 04, 2017, 08:25:39 pm »
Quote from: processedmeat
here somewhere perhaps Control Panels and Interfaces section:
https://web.archive.org/web/20160714065308/http://newwiki.arcadecontrols.com:80/index.php?title=Main_Page
« Reply #6 on: June 04, 2017, 08:38:29 pm »
The newwiki page wasn't captured, but here's the page from the old wiki.
https://web.archive.org/web/20160421175734/http://wiki.arcadecontrols.com/wiki/Spinner_Turn_Count
Info should be the same.
adder
« Reply #7 on: June 04, 2017, 08:49:37 pm »
Quote from: PL1
cool havnt seen that before
so if i understand right,  it looks like arkanoid, when using the usual spinner for that game (taito spinner), the bat should move across the entire screen (from one edge to the other side) if the spinner is turned about a third of one complete turn?
DarthMarino
« Reply #8 on: June 04, 2017, 09:34:12 pm »
Quote from: PL1
That sounds about right to me.  I made this video a while back dealing with the sensitivity settings and I do use Arkanoid as one of the examples.  I have the turn counts in the descriptions as well and I've add a few that aren't on the wiki. Not sure if it's all correct. Last time I played Super Sprint it felt way off.
adder
« Reply #9 on: June 04, 2017, 09:50:46 pm »
Quote from: DarthMarino
just watched your vid, perfect thanks
