Author Topic: trackball issue  (Read 983 times)
shitoken
  • Last login:May 30, 2025, 07:41:27 am
trackball issue
« on: April 26, 2017, 04:46:49 am »
Hi friends
My panel setup with I/O ultimate board from ultimarc with his spinner and rgb buttons. I did not bought trackball  because my control panel already have china made usb ball tracker which I plug into the mother board directly.
Now here is the problem: -  :banghead:
I have 1 real mouse with keyboard , 1 Spinner which plugged to I/O encoder (This both works fine)
But the trackball will not function until I remove the spinner from the ultimarc I/O board.
Is there a limit of max 2 mouse per motherboard?
I doubt should not be otherwise how other members can use spinners, mouse, trackball all at same time?
Because my control panel was cut to the size of this trackball,  I cannot replace the one from ultimarc.
Do you have idea what is going wrong my setup?
Thank you so much
« Last Edit: April 26, 2017, 04:48:24 am by shitoken »
