Author Topic: How would you mount mini joystick  (Read 1506 times)
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
« on: February 24, 2017, 11:17:21 am »
Going into my cell phone mini. I've seen steel wire ties used, I've seen glue ... was going to use the 5mm mdf for the cp but am open to other suggestions.
Now witness the power of this FULLY OPERATIONAL Mame machine!
  • Last login:Yesterday at 07:49:22 am
Re: How would you mount mini joystick
« Reply #1 on: February 24, 2017, 12:07:38 pm »
Since it's fairly thick, I'd make the part it mounts into the same thickness then cut the opening just big enough so it fits in there tight.
Either by filing the wood until it fits or 3D printing the part.
Then maybe a dab of superglue on the back edge that could be cut through if it needed to be removed.
  • Last login:Today at 02:06:03 am
« Reply #2 on: February 24, 2017, 12:27:57 pm »
As you mentioned, here is the lockwire method for mounting the Grayhill 04a joystick.
http://forum.arcadecontrols.com/index.php/topic,135525.msg1400031.html#msg1400031
If you have a dremel drill press with an X-Y table, access to a CNC, or a 3D printer you could use the approach that Yvan256 used here.
http://forum.arcadecontrols.com/index.php/topic,113763.msg1332763.html#msg1332763
rhoelsch
« Reply #3 on: February 24, 2017, 12:30:34 pm »
Badmouth: I'll think about it. You'd have to be real precise with that cut to rely mostly on friction for that. I'd be afraid to use it too hard.
« Last Edit: February 24, 2017, 12:32:09 pm by rhoelsch »
jeremymtc
  • Last login:August 25, 2025, 07:44:10 pm
« Reply #4 on: February 24, 2017, 02:01:33 pm »
I would drill a shallow counterbore in the underside of the CP, chisel it square to get as close a fit to the base as possible, then hot glue the sucker.
lilshawn
  • Last login:August 29, 2025, 10:11:37 pm
« Reply #5 on: February 24, 2017, 03:18:36 pm »
was going to suggest hot glue. glad i'm not the only one.  ;D
rhoelsch
« Reply #6 on: February 24, 2017, 03:32:31 pm »
Got an idea. Going to use one of these laminate samples and cut a mounting plate out of it. Very thin layer of hot glue to secure to the top of the joy base, and size to the top of the cp. Super thin so the short staff of the stick isn't hindered. Cover all with printed artwork. There is no bottom to the cp, else I'd try to sit it on there.
