Author Topic: Is this image vectorized?  (Read 4159 times)
80sarcadegames
  • Last login:October 01, 2025, 09:41:51 am
« on: February 21, 2017, 03:17:12 pm »
How can you tell if it is or is not?
I zoomed into it as high of a zoom that MS Paint would allow and I noticed some
of the "blocky" edges to the lines when you zoom in as close as you can
get with MS Paint.
Re: Is this image vectorized?
« Reply #1 on: February 21, 2017, 03:18:58 pm »
It's a jpg, so no, it's not vectorized. It might have been (and kind of looks like it was) at one point, but the specific file you uploaded can't be a vector image.
80sarcadegames
« Reply #2 on: February 21, 2017, 05:03:51 pm »
Thank you.
 :cheers: :cheers: :cheers:
So jpgs definitely are never able considered vectorized???
A Vector image must be either a .AI or a .EPS or a .PDF  or .TIF etc?
If a file image is a .AI OR .EPS or .PDF or .TIF does that mean it is considered vectorized?
Can a file image be a .AI or .EPS or .PDF or .TIF and NOT be vectorized?
I know that you must image trace with a tool or by hand to vectorize a raster image but can you then save it as a .JPG and have it keeps its vectorized state?
« Reply #3 on: February 21, 2017, 07:09:18 pm »
AI and EPS are both vector formats,
PDFs I +THINK+ can contain vector as well as raster images.
TIFs are typically raster. I don't believe they can contain vector images.
for AI and EPS, yes, both these formats +can+ container raster images. Imagine going into a draw program like Illustrator and pasting a screenshot into the image. Yes, it saves as AI, but that image is raster.
As for saving a vector image as JPG, no, I don't believe that's possible. JPG is really intended as a lossy raster format.
Oh, and WMF files (windows metafile) is another example of a vector format (albeit a quite old one).
Finally, Inkscape is a very popular opensource vector drawing package (a bit like illustrator).
SlammedNiss
  • Last login:Today at 03:14:01 pm
  • Mine Drags the Ground!
« Reply #4 on: February 22, 2017, 03:16:49 am »
.ai files doesn't necessarily mean it is a vector file, only that it was created using Adobe Illustrator. And yes, .pdf can also have both raster and vector images. I typically save my vectors as .pdf because when emailing proofs, a .pdf file is easily opened.
Btw, you're also forgetting .svg files. (Scalable Vector Graphics)
thatpurplestuff
  • Last login:May 10, 2025, 02:37:15 pm
« Reply #5 on: February 23, 2017, 01:21:39 pm »
Just to add to/clarify the above statements, TIF's can contain vector data in their layers as well.
« Reply #6 on: February 23, 2017, 04:59:41 pm »
^ Photoshop .psd's can also as well.
