Author Topic: Help please Player 2 button 3 won't work  (Read 1870 times)
P4LM4D0N
  • Last login:January 25, 2017, 08:08:33 am
  • Currently working on a Jamma cabinet
« on: January 22, 2017, 11:23:47 pm »
Hi! First of all in a complete noob at this stuff so any help would be great. I'm having troubles with button 3 on my player 2 side not working. All 6 buttons on player 1 work just fine and all the buttons on player 2 besides button 3 work too. I have tried switch out the switch that I have connected but that doesn't help. If anyone has suggestions or can tell me what I have done wrong it would be appreciated. Thank you!
processedmeat
  • Last login:Yesterday at 01:03:41 pm
  • Ikeakade Here I come!
Re: Help please Player 2 button 3 won't work
« Reply #1 on: January 23, 2017, 11:08:30 am »
You'll probably need to provide a little more info e.g. Mame or arcade?  If mame what kind of encoder are you using e.g. ipac, zero delay etc.  I would try taking a working button's wires and switch that with your non working button first.  Maybe the wires are faulty.  Then check the encoder and see if the headers are loose.
P4LM4D0N
« Reply #2 on: January 24, 2017, 01:14:24 pm »
It's a Arcade. I'm using a Pandora's box 4 with Jamma harness. I've tried using other wires from other buttons and even different switches. When I use the IO test on the butttons it's just button C that won't work.
« Reply #3 on: January 24, 2017, 01:18:29 pm »
Do this with the machine turned off:
Bust out your Multimeter.  Test continuity from the PCB to the actual button contacts.  Test the ground continuity while you are at it.
Button C is pin # 24 (button # 3).
Troubleshoot.
P4LM4D0N
« Reply #4 on: January 24, 2017, 01:32:04 pm »
Will the pins differ if it's for a 6 button harness?
« Reply #5 on: January 25, 2017, 04:53:09 pm »
No. You should be fine.
There is usually a kick harness for the extra buttons.  That comes from elsewhere.
The name kick harness is from SFII where the bottom row is the kick buttons. Hence kick harness.
Some JAMMA + harnesses have extra buttons, but only go up to 5 buttons IIRC.
But you're only concerned about button 3 so you should be OK regardless.
DeL
