Author Topic: 2017 Chuff thread  (Read 160698 times)
CoryBee
  • Bopity Boopy
Re: 2017 Chuff thread
« Reply #240 on: May 12, 2017, 06:30:18 am »
Hi guys, glad to see some familiar faces from when I was last on here.
Figured I'd share some ---steaming pile of meadow muffin--- as well. Moved from Northern California to the Southern Part of France called Nice, had to leave a lot behind in my workshop as space is a commodity here. Found an old hole in the wall store turned garage near my house to turn into a workshop. Has been about 5 months since I got to cut some wood and well, idle hands and all.
I plan on setting up a CNC and a bunch of woodworking tools to make some Arcade machines again, maybe sell some to the Frenchies here. Hipster crap has gone big recently in the cities. Mainly just to keep myself busy building a Man cave though.
  • Last login:Today at 01:59:06 am
« Reply #241 on: May 12, 2017, 08:58:01 am »
Bro, you took wearing a puffy shirt across Europe and trying to get laid to a whole new level. :cheers:
  • Last login:February 19, 2024, 12:40:25 pm
« Reply #242 on: May 12, 2017, 09:33:10 am »
Sweet the CoryBEE!
still waiting on that GettyLeeCade!
CoryBee
  • Bopity Boopy
« Reply #243 on: May 12, 2017, 10:08:47 am »
Haha, I never half ass, always full ass baby
Sweet the CoryBEE!
Must have been a while cause I have no idea what you're talking about!
What do you guys think, should I do a build log on "Everything Else" showing the shop/cave come together?
« Reply #244 on: May 12, 2017, 10:11:34 am »
Just a joke thing posted after the doors thing you did!
CoryBee
  • Bopity Boopy
« Reply #245 on: May 12, 2017, 11:49:44 am »
That bartop was a work of art!
  • Last login:Today at 08:46:53 am
« Reply #246 on: May 12, 2017, 12:16:03 pm »
YES
  • Last login:October 19, 2022, 12:01:54 pm
« Reply #247 on: May 12, 2017, 02:18:14 pm »
It's rare that I agree with Jim.  Do it.
CoryBee
  • Bopity Boopy
« Reply #248 on: May 12, 2017, 03:52:56 pm »
Thanks for the support. I'll be starting on it on Monday or Tuesday.
It is a small space that is very old, but I can make it work :D
  • Last login:Yesterday at 08:42:41 pm
« Reply #249 on: May 12, 2017, 06:41:17 pm »
So what are you going to do about the power situation?  It's my understanding that wiring in old structures in Europe is.... questionable at best.  Also are you going to run stuff through adaptors or are you going full EU/PAL on us?
  • Last login:June 13, 2024, 04:24:33 pm
« Reply #250 on: May 12, 2017, 07:42:25 pm »
You never go full EU/PAL
CoryBee
  • Bopity Boopy
« Reply #251 on: May 13, 2017, 06:16:18 am »
So what are you going to do about the power situation?  It's my understanding that wiring in old structures in Europe is.... questionable at best.  Also are you going to run stuff through adapters or are you going full EU/PAL on us?
I have electrical guys coming out to do the wiring next week. Probably going to charge me a butt load, but they said no problem as that spot had electricity that was removed within the decade.
I have some smaller stuff going to be ran through adapters that I brought with me for some of the cordless stuff, but am buying all new tools as I sold all the larger ones before leaving the states.
I think that was the hardest part of the move, ---fudgesicle--- the neighbors, I wanted to bring my table saw and drill press.
Locke141
  • Last login:June 09, 2024, 10:35:34 am
  • Never grow up.
« Reply #252 on: May 13, 2017, 06:28:08 am »
Now you can go SCART with out having to open a CRT.
Just spent a few HR looking at RGB converting some CRT's to start last night.
http://shmups.system11.org/viewtopic.php?f=6&t=56155
CoryBee
  • Bopity Boopy
« Reply #253 on: May 13, 2017, 07:03:14 am »
For now I'll just be making Bartops and some maybe unique shaped arcades, I never got into restoration or using original hardware. Started off jamming laptops into jigsaw cut bartops http://forum.arcadecontrols.com/index.php/topic,120067.0.html and will probably use raspi or the pandora game boards.
Locke141
  • Never grow up.
« Reply #254 on: May 13, 2017, 09:37:02 am »
Build as you like but SCART opens up some opertunitea worth considering.
SCART makes lots of Eurapion CRT tv's RGB ready, just like arcad monitors. With very little work your should be able to use a pandora box Vea SCART as they have an RGB out. Lots of guys on BYOAC use VGA to SCART cable in there builds with mame. You may be able to do the Rpi as well Vea one of the hats that have RGB out. You wouldn't be the first to use a small CRT in a bar top and it should beclose to an acteral arcade monitor.
« Last Edit: May 13, 2017, 09:48:25 am by Locke141 »
CoryBee
  • Bopity Boopy
« Reply #255 on: May 13, 2017, 03:10:37 pm »
Interesting.
« Reply #256 on: May 13, 2017, 07:09:51 pm »
The refresh rate is going to be crap on scart though.  No such thing as a perfect format before svga came along.
Locke141
  • Never grow up.
« Reply #257 on: May 14, 2017, 06:36:58 am »
It doesn't seem to have a negative effect on the frame rate. In fact it should be as fast as the TV can sports.
Driving a TV directly has some advantages. The quality is superior to composite or S-video, and as the video card's TV encoder is completely bypassed, custom resolutions and refresh rates can be programmed. On the down side, this method can require some experimentation to get right.
(14.76 MHz for PAL, 13.34 MHz for NTSC.)
https://www.mythtv.org/wiki/RGB_Scart
« Last Edit: May 14, 2017, 06:40:02 am by Locke141 »
« Reply #258 on: May 14, 2017, 12:53:15 pm »
PAL is 25fps and NTSC is 30fps.   Most game consoles originate from japan, a ntsc region.  That means that games are often shoddily ported to pal and since it has a lower fps, either the game will run slower or 5 fps are cut internally, often resulting in a more jerky picture.  In an arcade situation it matters less, but it still probably matters with some games.
« Reply #259 on: May 14, 2017, 05:59:01 pm »
Pinball and craft beer at Hay Merchant.  The food is freaking amazing here.
« Last Edit: May 14, 2017, 06:02:05 pm by pbj »
« Reply #260 on: May 14, 2017, 08:20:42 pm »
Eh I dunno... that's got kind of a hipsterie vibe.  Not sure if awesome or awful because of it.
« Reply #261 on: May 14, 2017, 08:23:48 pm »
Here's to drinking double french quarters just to deal with in laws...
« Reply #262 on: May 14, 2017, 10:42:50 pm »
It's 100% hipster.  Deal with it and join our rooftop parties.
« Reply #263 on: May 14, 2017, 11:11:42 pm »
Will there be attractive, but not threateningly so, blonde millenials begging me to play Nintendo switch with them? :D
Locke141
  • Never grow up.
« Reply #264 on: May 14, 2017, 11:46:55 pm »
Sounds fun.
My Dad is big into the local Elks and he is always trying to get younger members. I been telling him to fill the bar with old pinball tables and a select few arcade games. I also told him to fill the old large, now empty pool room with new tables, ski ball, air hockey, a projector with an Xbox one/ PS4. If they want younger members, then they need to do and have things young people would want to do. I think the average age is over 70.
« Last Edit: May 14, 2017, 11:59:33 pm by Locke141 »
CoryBee
  • Bopity Boopy
« Reply #265 on: May 15, 2017, 05:34:35 am »
Morning Hike in some mountain region of southern France.
« Reply #266 on: May 19, 2017, 10:24:52 pm »
Third weekend in a row in the coast, I don't know how you flyover country people manage.
Anyway, after 3 years of wondering and hoping, I can joyfully confirm that a pinball machine and dolly fit in a Scion xB.
« Last Edit: May 19, 2017, 10:27:23 pm by pbj »
« Reply #267 on: May 19, 2017, 11:05:52 pm »
What pin is that, a KISS machine?
« Reply #268 on: May 19, 2017, 11:25:39 pm »
....FIRE......POWER.....
« Reply #269 on: May 20, 2017, 12:16:39 am »
I've never played that one before. Looks pretty sweet.
« Reply #270 on: May 20, 2017, 01:00:15 am »
It is actually very fun and very fast.  I bought this years ago, in horrible shape, and turd polished it to respectability.  It does suffer from lack of a goal during multiball, but getting multiball going is difficult.  I'll contemplate adding the "mission" roms...
« Reply #271 on: May 20, 2017, 01:06:29 pm »
Love Firepower
« Reply #272 on: May 20, 2017, 04:08:02 pm »
Today is the first day in 21 years that I haven't been employed. Now I know what PBJ feels like.
thomas_surles
  • Last login:June 19, 2023, 07:20:00 pm
« Reply #273 on: May 20, 2017, 04:36:01 pm »
I thoght you just got a new Gig?
« Reply #274 on: May 20, 2017, 06:02:21 pm »
I start it July 10.
« Reply #275 on: May 20, 2017, 08:56:31 pm »
Lol wat?  I've been working nonstop since I was 15.
 :dizzy:
  • Last login:March 11, 2024, 11:02:52 pm
  • Bitches love Centipede
« Reply #276 on: May 20, 2017, 09:11:29 pm »
 :dizzy:
They got you, slave.
%Bartop
« Reply #277 on: May 20, 2017, 10:32:20 pm »
God loves a working man.
(I hope)
Locke141
  • Never grow up.
« Reply #278 on: May 20, 2017, 11:50:12 pm »
He might love a stay at home Dads more, and you'll need it.
Lost 20 LBS, my kids and I are never close, and I have some time for projects. Still, I really want to get back to work.
« Last Edit: May 20, 2017, 11:52:20 pm by Locke141 »
« Reply #279 on: May 21, 2017, 08:37:20 am »
(I hope)
Keep taking online surveys. Sooner or later you'll earn enough internet points to buy a voucher to heaven...
%Bartop
